Stripping a GTR so there are a few things that i've taken out so far, if you need anything else just shoot me a PM.
GTR twin exhaust.
From front pipes back including racing cats.
Current has straight pipes where the muffler should be, but i've also got the JASMA muffler to quiet it down. This exhaust sounds fkn awesome.
$670
R33 GTR brembo brakes
Calipers, rotors & pads
$1700
Brand new cannon muffler
2.5" inlet, 3" outlet
$50
R33 GTR Carbon-look dash cluster
56xxx kms
Perfect condition, no marks to cracked brackets etc.
$280
R33 GTR carbon look din cluster
Can supply plug and harness too if required.
$180
Exterior
R33 Series 2 GTR front bar with indicators $400
Nismo front lip (fibreglass, got a crack) $100
R33 GTR Grill $250
R33 GTR Front guards with badges $650
R33 GTR guard raisers (needed when fitting gtr guards on gtst) $100
R33 GTR series 2 headlights $400
R33 GTR bonnet $500
R33 GTR sideskirts (2 piece) $100
Interior
S3 red stitching door trims - $100 each
S3 red stitching rear seats - $180
Complete Boot interior - $130
Centre console with GTR coin badge $80
Drivers door window switch - $50
Complete Glovebox - $40
Front and rear strut braces - $80 each
Stock BOV - $50 each
Dash cluster surround - $20
Door sills - $50
If there is anything you want, just ask.
Small things i will post, but big bulky things im not willing to, jsut dont have the time.
Best to PM me on here or sms me on 0433010130
Edited by mill-180
https://www.sau.com.au/forums/topic/297356-wrecking-1997-r33-gtr/
  • Replies 43
Posted Images
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
