Engine setup is rb30det 1.06 3540 with a Turbosmart 48mm gate mounted out of the exhaust housing.
On spring pressure (15psi) the gate holds boost perfectly with perhaps 1psi creep maximum.
Ive now installed a Gizzmo IBC and now find that even with the gain on minimum setting and duty on 35/100 im still getting quite a bit of creep. Its installed as per the manuals reccomendations.
I would be interested to hear from guys running the same controller on a similar setup to mine.
Testing extensively on the roads isnt an option really either as 3rd gear traction isnt too good, and i really dont want to be revving out fourth gear on the roads. Will be taking it for a tune in a few weeks, but would rather get this solved first as otherwise ill buy teh same solinoid and hook it up to my link which apparently works well.
Any opinions would be great.
Cheers
Edited by SirRacer
https://www.sau.com.au/forums/topic/297396-gizzmo-ibc-boost-controller/
how old is the IBC? they have been superceeded by the MSIBC. That said we have used heaps without issue. some of the early IBC's had the menus set up opposite to the late ones from memory so you might find it is gain your adjusting not Duty. If you continue to have issues let me know as im good friends with the owner of Gizzmo and i am happy to test the unit in our race car (we have run both IBC and now MSIBC with no issues) if it is faulty we can upgrade the firmware to the latest.
Hi Trent,
That would be Ray Hall i presume? He seemed like a good sort in my dealings with him and hes a New Zealander as am I. Half the reason i brought the product was his support is supposed to be very good. That said my email to the NZ guys has gone unanswered for quite a while. I thought the MSIBC was no better control wise, just had more features????
The IBC would maybe be 18 months old. I have really just used it as a gauge so far as ive had so many teething problems with my car. Would love to send it to you but im in New Zealand, but cheers for the offer
How can i tell the model number? Button 1 adjusts the duty (this starts at 10 from memory) and button 2 the gain. 0/100. Are my gain settings perhaps too high? When i drop them down the car seems very sluggish getting onto boost.
Am i better to just flick it on and get another solinoid to go into my link or buy a Blitz etc?
Hi Trent,
Nah Ray Carter is the owner also an NZ'er, hes living working over here now in melbourne, GIZZMO is now based here also. Going gang busters in the UK and USA.
Try contacting him direct here: http://www.gizzmoelectronics.com/Contact.html he usually emails back "quick as bro" but if you still cant get through let know and i will forward your details through personally.
The MSIBC is one of the best controllers on the market, it is as good as the BLITZ dual solenoid jobbie we had on our car. The IBC was a good unit too and all the things he wanted to do processor wise and feature wise went into the MSIBC.
With the gain i normally datalog (road) or map (on the dyno) the boost and get my target boost with the gain set to zero, then i increase the gain untill i get a spike and back it off about 3 or so units. Most of time i end up between 10 and 25 units of gain. It is hard to get a seat of the pants setting because the more gain you feed in the better it feels but it causes it to spike too much especially when dropping back a gear and stomping on it... this is the same with all boost controllers with gain control.
Edited by URAS
Got hall and Carter mixed up. I emailed the Aussie link and got a responce from Ray straight away which is great.
Good to know your gain levels are much lower as that seems to be the issue then. I will drop them down and then work from there. What would be an abnormally high gain setting?
Thanks mate
Edited by SirRacer
I had a absolute nightmare with my MSIBC initially, worked for 5 minutes on the dyno and the solenoid just stopped responding to the controller, and was given the syringe test as well.
This is a PM a fellow sau member sent me when I needed assistance setting up my MSIBC
http://www.gizzmoelectronics.com/Support_Instruction.html
http://www.skylinesaustralia.com/forums/in...t&p=3126267
Basically you turn up the solenoid duty cycle to get more boost, to do this is easy (Adjusting duty cycle section of the manual)..
B1 = button 1
B2 = button 2
Hold B2 for 2 seconds (brings us to the closed loop setting, if you want open loop press either button once to switch between)
Now that your at the closed or open loop setting, hold B1 & B2 together for a second
Now we're at the solenoid duty cycle menu, B1 turns the duty cycle up (or down I forget), B2 does the opposite (if B1 turns up, this turns it down)
Hold B1 & B2 for a second, now we're at the Gain menu (how quickly the turbo comes to boost), B1 turns it up, B2 turns it down
Hold B1 & B2 for a second to get back to the digital boost gauge.
Personally - it works great for me. I read somewhere(I think the gizzmo manual) that one way of combatting creep is to lower the Duty cycle a few degrees and increase the gain, that way, by the time it creeps, the solenoid has already stabalised the boost. Also, make sure you run it in CLOSED LOOP.
Getting heaps of boost is easy, its holding it that seems to be the problem. I think doing by the sounds of that that my solinoid may be buggered or perhaps ive got a controller fault.
Are the MSIBC's any better than the IBC's??? I know they have more features, but i was under the impression they have the same control.
Here are some pictures anyone of how i have it mounted. The line coming from the left of the T piece by the solinoid goes into the intercooler piping.
Only see some slight issues, the un-used port on the solenoid needs to be facing down (doubt it's causing your problems though). Is the solenoid close to any heat sources (turbos, either manifold, intercooler etc) ?
edit: just read my manual, originally said un-unused port facing up, it's actually facing down
the port orientation is unimportant, its only wise to face it down to stop shite dropping in.
SIR; try plumbing it up as a actuator, ie right angles thru the solenoid and to the forward most port on your gate (below the diaphragm). If you were seeing slight boost creep with the thing at gate pressure you might find the added restriction of the controller is just making this worse.
It should work the way you have it hooked up (as this is the way i always do it with both ports of the gate) but the physical setup you have might just be to close to boost creeping anyway, or the unit is playing up.
Hi Trent,
Will keep playing with it. I dont think a 48mm gate out of the exhaust housing is likely to boost creep under any circumstances really.
Duty is set to 10% with gain now set at 0.
sorry in your first post you said it was creeping 1psi ? if its creeping @ gate pressure there "could" be an underlying issue made worse though i doubt it.
Duty @ 10 % is doing nothing, i havent had a setup yet that has seen an increase in boost at all until @ least 20-25 duty.
Have you got a bleed valve to bang in to try? or try it in actuator mode like i posted previous.
Edited by URAS
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
