hey guys, i got defected a couple of weeks ago for my ride hight and boost controller. i went through regency and the guys defected me for a few more things.... now i have fixed everything but my battery. my battery is located in the boot of my car. there is a hose which is ment to conect to the side of the battery and dispose of any gasses the battery produces.... i have spent practicly all my money fixing everything else. so if anyone has any ideas or can lend me there battery for the morning (i am willing to give some money to borrow) i would very much apprecciate it... thanks :down:
oh and just to make things difficult my appointment at regency is 11:20am thursday 26th...
I have a 550cca Sealed Battery i could lend you...its brand new, it is meant to go in my car, but i haven't got round to rewiring my + and - cables in the boot.
Omg... you are a legend!!!!!!! i live at christies beach... does it have the inlet which the hose is ment to connect to....? If so, if i give you $50 would you mind if i borrow it for about 2 hours just to pass regency????
I am at Aldinga, no it doesn't, it isn't needed as it is a sealed battery...as far as i am aware.
EDIT: Why not go to the Lonsdale Checking Station.
i tried to get into the lonsdale but they are full for the next three weeks... my car runs out of rego on friday so if i don't get it passed i'm screwed... i think my battery is a sealed one as well... i will check and get back to you tomorrow... cheers man!!! oh and i'm pritty sure i've seen ur car a fare bit... out the back of cash converters at noarlunga rite??? nice by the way!
Sealed batteries don't require the breather hose
yea thats what i keep hearing and thats what i thought... but the dude at regency said it has to by law.... although he was proberbly just trying to get me for everything....
cheers dude
Yup that's me, how did you know?
I haven't used the battery yet, so it may need a charge, i can drop it off tomorrow or Wednesday so you have time to charge it if need be.
Oh forgot to mention, the battery is a little bit taller then my current one, so my + & - leads don't connect to the battery, so it may not fit your car either.
ahh... cheers man but i'm workin down at tea tree plaza monday tues weds... and i'm staying at my mums till weds night... so i will think of sumfin up n get back to you 2moro arvo...
i was just lookin at ur photos and i realised ur SAU sticker on the side of your car... i check it out everytime i pass it lol white skylines are the best thats why i have one....
the fully seal gel batteries like oddysey or optima are legal
"sealed" lead acid are not - these ones are called sealed since they dont require the addition/replacement/topup of fluid
http://www.energymatters.com.au/renewable-...adAcidBatteries
Sealed Lead Acid Batteries
Sealed lead acid batteries are also known as valve regulated lead acid (VRLA) batteries, recombinant batteries and often called maintenance-free lead-acid batteries. Examples of VRLA batteries are:
Absorbed glass mat (or AGM)
Gel cells
The term term "seal lead acid battery" is misleading: a sealed battery would be a safety hazard due to overpressure risks the battery is overcharged. There is always a safety valve present, hence the name valve-regulated. Even the term "valve regulated" does not really describe this technology. These are really "recombinant" batteries. This means that oxygen evolved at the positive will mostly recombine with the hydrogen ready to evolve on the negative and thus prevent water loss. The valve is only a safety feature in case dangerous amounts of hydrogen are produced.
Well, that's what i have, so i am boned too...i went and bought it because i thought it was legal, as the battery i have atm is the standard maintenance type.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
