Im in the process of getting my front facing plenum up and running but the throttle cable is too long. Im not using the adapter as ive got a bigger throttle body that fits right onto the plenum. Ive got around 50mm slack. What are my options?
https://www.sau.com.au/forums/topic/297417-shortening-the-throttle-cable/
Pull the cable from the pedal end through till its firm and get a cable clamp and clamp it off at the pedal to take up the slack. Works a treat. Or you can pay big $ and get it shortened.
this is the way mine was shortened, seems to be working fine so far. a bicycle shop should be able to sort you out with a fitting to clamp the cable.
yeah i know it will cost around $80 over here, i just need a quick fix so i can get it running. the new cable can wait a week or so till i sort out the bugs with the new plenum and injectors.
Cable ties then - answer to the worlds problems! :)
I got a longer one to suit my RB30DE and had to shorten by 50mm. I was able to gently cut the outer sleeve at the 50mm length and then with side cutters cut each ring of the outer sleeve off.
Took a bit of effort but got it there. I shortened the firewall end where it seats into the firewall bracket
Nigel
went to a bike shop and got a little clamp for the pedal end - works just like the stock one except its not welded/brazed. a grub screw clamps down the cable. now ive got the awesome task of finding out why my ECU says my TPS is 13% open when at idle :\
i pulled the stock sensor off the original throttle body and put it onto the Q45, then its just two screws that hold it in place get a mate to watch the computer while you move it around to get the correct throttle closed % (and make sure it hits the correct fully open %) mine closed sits on 0.1%
Edited by TiTAN
You can use the throttle cable from a U12 bluebird/pintara/trx.
It has the same firewall mounts as the r32 and fitted perfectly on the greddy copy inlet on rb25/30
I believe the same age pulsar fits, something like a n13 ca18de or similar. P10 and p11 primera fits too, but i dont know if they come out is aus
Yeah mate I tried that and fully closed it's at 13%. I'll have a play with it later today and see what I can get it to do.
sweet! thanks for the info mate.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
