  • Replies 130
Oysters were surprisingly fresh, although obviously not fresh enough for Bob and Steve :P
Yeah mate def not fresh enough.. :P i stuck with the octopus balls instead. :D
Fantastic stuff Charles! Was great to meet yourself and the team. Will have trouble remembering all the names..lol. Hope to catch up again.
Yeah mate def not fresh enough.. :P i stuck with the octopus balls instead. :P
Hehehe, good balls ay? :D
It was good to meet you too mate and others that I haven't met before :D
Hi guys, uploaded some photos:
http://s384.photobucket.com/albums/oo281/m...hi%20Meet%2009/
I couldn't be assed blurring the photos with the plates on them, so I just mainly took non-plate photos.
Let me know if you want a particular photo in higher res. Photobucket has shit-all quota so I can't load decent photos sorry.
Thanks for the photos!! :)
Maybe I'll get all the photos off you one day on a CD or something :down:
nice photos
love the quotes :)
I don't think I have ever eaten so much fish.
The sushi, prawns, curry beef rice, chicken + the rest tasted quite good for that price.
I would go back again.
Yeah, I wouldn't mind going back there sometimes soon :down:
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
