Check in the engine bay fuse box. I don't know if the 33 has a fuse or relay there, but it might be worth a look.
yer checked there too. swapped the AC one with one of the others under there that had same thing plugged in...
also pulled out fan speed control unit cause it lookd dodge and resoldered... still no dice.
'the whole unit doesn't power on. no display or lights turn on...
and its getttttin warm now too! curse you summer!
https://www.sau.com.au/forums/topic/297449-air-con/#findComment-4953978
do u mean just the a/c button wont work or the whole climate control unit doesnt work?
i take it your talking about the whole climate control display so i doubt the compressors at fault, if u have checked ALL fuses and relays properly, the next thing u can do is check that theres power behind the climate control unit.
OR seeing as its just happend after u jump started it, i cant realy see how it would happen but u may have fried the climate control unit seeing as its electronic but id always thought if it was jump started wrong the ECU would get fried 1st. were the jumper leads protected by a suppressor or anything? quite a few r33s getting wrecked here in perth on these forums so u could probly pick up a climate control unit for under 50bux atleast it eliminates that.
or take it to an auto sparky lol
https://www.sau.com.au/forums/topic/297449-air-con/#findComment-4954116
would the compresser effect the LED screen in the Control Unit because it doesnt even seem to turn on at all... no screen lights or numbers are displayed... even tried the self diagnostic thing where ya hold down the off button for 10 secs. no dice.
https://www.sau.com.au/forums/topic/297449-air-con/#findComment-4954122
Ahh, the CCU won't turn on.
Okay, by looking for fuses I assumed that the unit was working but the compressor wasn't.
I'll agree with jimmys-33T, the CCU sounds like it's fried.
Ask around and see if someone will let you borrow one to see if a unit swap will work.
The last thing you want to do is to buy one and find out that the issue is somewhere else.
https://www.sau.com.au/forums/topic/297449-air-con/#findComment-4954136
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
