Ok so i bought the car with a stock cassette player and speakers... damn it was bad quality :)
So i bought myself one of these http://www.alpine.com.au/products/product.asp?modelID=408 for $340 brand new (thought i was a bargin considering the RRP on the alpine site is $699)
The unit may be abit overkill for me but i wanted the 2.2" screen.
So my stock speakers do sound alot better then before, but the problem im facing now is i cant get some decent sound over the noise of my exhaust (starts to distort) :P if that makes sense.
Looking now at getting some decent quality front and rears and i think its a must to get some sound deadening also. Just wondering what is the best setup of speakers and other things
for the headunit i have / car. (not too knowledgeable in audio stuff)
Thanks in advance :)
Ok the 50x4 amp in that unit is not going to cut the mustard if you want to get over the top of your vehicles noise floor ( the sum of all the noises created by the car eg, wind, road, tyre, exhaust, engine etc). Firstly what is your budget? secondly don't bother with rears unless you plan on using them for low frequencies (below 250Hz).
If you want to get away with minimal cost but end up with a reasonably good quality system I'd suggest
1) A good 2 way component set of speakers
2) A 4 Channel class D amp (4 x 150watt) 2 x 150watts for fronts & 1 x 300watt for sub.
3) A subwoofer
Contrary to your request I've suggested a sub because you won't get the lower frequencies & thump without spending a considerable amount of money on the front speakers and installation.
So your budget will come into play as to what you will be able to get, if you want good quality and don't mind getting S/H gear shop at the for sale section at MEA but don't forget to make an allowance for installation:
http://www.mobileelectronics.com.au/forums...hp?showforum=41
Edited by mosoto
Nice deal on the IDA-X305, always liked that unit... good price on that for you there too!
anyway, Alpine do a package deal that comes with:
1x MRP-F600 4x100WRMS 4 Channel Amplifier (yes, its a true 100WRMS)
1x SPR-17S 17CM Type R Component Speakers (tweeter positioning is something to think about, they're big suckers)
1x SPR-69C 6x9" Type R Coaxial speakers (Ask your dealer to swap them for SPR-17C for you, i know i do for customers, as the 6X9"s wont fit)
comes to about $1300 RRP, and the pack goes for $999. works out that you get your rears for free.
Good sounding speaker in the $349 range, you can get a speaker with a nicer high end, but the type r really does well, and makes a LOT of midbass.
Mosoto:
Since when are 4 channel amplifiers class D?
I can tell you straight up. a good mp3 headunit, and some rockford fosgates punch with an amp.. I went that road and wholly f**k never had so much bass from 6" speakers.
Dont beleive me pop into a local chinabarn and check them out!
oh an all for under $500. Best bang for your buck and sounds great.. spending any more that $5-600 on your stereo is silly.
Sound systems belong in your loungeroom. Cars belong on the street with some power :D
speakers, head unit and an amp for under $500? what modle speakers and amp ect
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
