Originally posted by [ABU53]
dude, most workshops etc do them.
i have a mate who can make them oh, and also, i know that ARES SPEED in brissy can do basically any design/brand
ssshh .. dont tell boxhead! he will want in on the rice too :) it will go well with his high powered nismo window sticker :D
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-51785
Chucky
I can do the sticker for you at a good price in whatever vinyl you want just let me know the brands....
$8 each for normal size ones
HKS
APEXi
BLITZ
TEIN
BOMEX
PUNCHED OUT CAT (DRIFT CAT)
CUSCO
FALKEN
OS Giken
C's
EBC Green stuff
GReddy
GAB
Central Circuit
"Street Racer" in Japanese
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-51926
All depends on the vinyl and how you remove them. You should never use chrome or brushed alloy-look vinyl if you want to save your paint due to the amount of heat transfer....normal plastic vinyl is fine so long as you wash the car regualy.
When removing them leave the car out in the sun for a while so the vinyl softens up a bit then remove. I have never had a problem....also depends on the condition of the paint.
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-52098
Sorry Cam, didn't mean to try to outsmart u there. I read 'in HPI' a little blurb explaining that the so called punched out cat was actually the URAS monkey. After some research, I found that it isn't true and that HPI screw up more often than not. (see link for proof)
Sticker looks good though....not too big.
"Can I have one"
"No"
"Can ....Lenny have one"?
oh yeah, I'll buy one btw
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-52820
Actually, here is some contradicting evidence.....i been doing more research and have been finding more info that suggests the 'punched out cat' is the URAS monkey!
eg: http://www.uras.co.jp/2001tokyo.htm
http://www.uras.co.jp/goods.html
anyone who can help me out with this one??? Cam???
Its really bugging me now
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-52828
From what I understand the PO Cat was originally drawn on cars by drifters after an accident....most likely, Uras actually took the PO Cat and stylised it as there logo due to the amount of drift cars they build. The question is simple, do you want the PO Cat like I posted? If so just tell me how high you want him and on what vinyl and I will make it.
private email me to discuss payment etc.
https://www.sau.com.au/forums/topic/2975-car-stickers/#findComment-52859
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
