4my Son Bday Cruz, Hey All Come And Have A Cruz And A Sausage Sizzler
Hey all. Its Adrian Lee (4MY SON) here, please come and join my family and friends to help celebrate my memorial 23rd birthday.. On SUNDAY 20TH DECEMBER 2009.
The family will bring out my baby 4MY SON for this special occasion.
My brother Matty and my little sister Kara, AKA (Little Ganxta),are also arranging sausage sizzler and drink for all those who attend.
Therefore we are asking for a gold coin donation for the map.
This cruz will start from Burswood Dome, Great Eastern Hwy near the park, meeting at 10.30am leaving around the 11.15am. Matt and Kara will be there earlier just look out for the Pink Onevia and Matt’s dardy KE 70 Corolla.
Hope to see you all there bring you friends and mates all types of cars welcomed even your mums!!!!!!
Please text Matt only on 0405 629 761, so as we know how much food we need to bring.
Love to see all the old and new crowd come out to help celebrate my birthday..
Love always Adrian
Many Thanks
Heather (Adrian’s Mum)…
to the guy driving the white 33 skyline 1bcl### do us all a favour please go and hand your licence in you caused an accident on the freeway this afternoon and totally ignored it an sped off
you have no respect for other ppl on the road for doing shit like that i meen who the f**k stops on the freeway because they missed an exit go to the next one and turn around easy as that
im not a keyboard warrior would have said to your face but didnt want to cause any dramas on someone else day end rant
i watched this retard in action and almost rear ended the guy who also stopped on the exit lane to give way to him . I had a rant when i reach north mole but all i got was a dumb smirk out of him . I was fuming but couldnt get out of hand with my kids near by . Pretty sure his details were taken by the other cars involved .
i was the guy who let him in. i only did simply because i thought he was going to cut infront of me. then when i was going to keep going he took off.
you mate are a dumb flamin mongrel for not stopping. i hope you get caught
    • To clarify, I meant nismo bushes, not control arms (don't even think that's a thing for my car). So the suspension specialist said, if I buy those nismo bushes which are perfectly centered it will cause my car to veer in one direction. Whereas he said the current offset bushes that I have were put in on purpose to fix that issue. This will be my third wheel alignment if I put these bushes in lol. My chassis is straight, all my rails are clean.
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
