hello, im looking at ecu options for my rb25. looking for 240+rwkw with gcg hi-flow and supporting mods.
basically im down to:
envy imports nistune ~$1300
ems stinger ~$1400
full management (haltech, pfc) ~$2400+
money is a factor, obviously, otherwise id just fork out for a haltech and be done with it (and id drive an r34 gtr lol)
i previously had a nistune which may have contributed to engine failure. the car was running so rich it gunked up the motor and seized a valve. and so i am leaning towards the ems stinger.
what i want to know is this. the stinger apparently only has 4 output cycles (forgive my lack of ecu-speak) for injector pulse and/or ignition firing. im told that in 6 cylinder applications tuners use 3 outputs but apply them to 2 cylinders each.
to my limited knowledge, this sounds very inefficient and defeats the purpose of multipoint injection and sequential ignition. im told the drivability will suffer slightly off boost, but peak power etc will be fine.
however an advantage is a map sensor, which seems a much better setup with atmo bovs and decent power etc.
do the cylinders all fire one after the other ie: 1.2.3.4.5.6 (whatever the order is)
or 12.....34......56?
Autronic SMC is 1800ish from memory, plus tune would be in the haltech ballpark.
link/vipec is another option, they make a skyline plug in unit, I would take that over a PFC. Factor in a MAP sensor based ECU is saving you money on a Z32 MAF, this 300$ can be used on the ECU, or pocketed.
Any ECU is only as good as the tune, cant blame the nistune for the motor death.
if the stinger only has 4 injector drivers dont use it on a 6cyl engine, you need to batch fire the injectors so you end up wasting heaps of fuel. providing the tune is good there should be no reason for it not to be just as good using nistune as using the haltech
the standard firing order is 1 5 3 6 2 4, fired sequentially. there will be a haltech, or a vipec or what ever you pick that will support sequential fire and inject. even EMS has a sequential ecu that supports 6 cylinder engines. if you go for the 4 output setup you will need to setup a wasted spark ignition, like the 3/2 falcon commodore coil packs. and as TiTAN has mentioned, batch fire your injectors.
if it's tuned well the nistune is a good option. which is the same as the other 2 really. they are only as good as the tune that's in them. so considering it's price and the factory like features it retains I would put the nistune at number 1 preference of those 3 options. or have you considered power FC? they have been great for me in all the cars I've run them in.
anyway, of the 3 you suggest I'd be talking to envy about what you want but I'm sure if tuned right the nistune will be good. :D
How come you list nistune seperately from full management?
because nistune uses airflow meters (as does pfc) which my tuner is not a fan of. also, nistune cant be retuned. if you make any modifications later nistune is much harder and expensive to adjust than a plug and play ecu eg: haltech.
if i was an envy imports regular id probably lean more towards nistune, i have heard a lot of good things about it. but my tuner has advised me differently. and i plan to sell the car soon, im sure whoever buys it will appreciate an ecu they can easily retune if they add modifications.
the nistune has on the fly tuning.. who ever told you it didnt either lied or were misinformed.
is that right? when i had it done last year the story was it cant be re-tuned. so now they save a tune file onto a chip and can basically cut + copy new information into the chip?
very interesting...
oh well. for a few hundred $ more i hope its worth staying loyal to my preferred tuner.
You are talking about an oldschool eeprom remap, a nistune is nothing like this. A nistune has real time tuning support like a full aftermarket ECU, infact I would say it is better than most aftermarket ECUs as it looks stock and retains all the factory features along with almost every feature a full aftermarket ECU has. The nistune is light years ahead of the EMS stinger which is essentially a downgrade as it doesn't have 6 injector drivers.
If they told you that then they must not have installed a nistune and probably just did a crappy remap, the reason I say this is crappy is because most tuners can only be bothered taking the ROM out and erasing/programming it a few times. This means you only have a few shots to get the tune right unlike a real time board where you can easily make 100s of corrections in an hour.
An AFM is more accurate than a MAP sensor as the MAP doesn't take into account air temperature, remember 30psi of air at 10c vs 40c is a big difference! not to mention that if you change any of your intake that your tune will be completely out, this is as any change in flow will change the restriction and hence the pressure of the air. If you must go MAP make sure you have some form of temperature compensation.
This is completely true, avoid batch injection mode as it is a massive down grade from the standard ECU.
Personally I would take the nistune without hesitation as it is a fantastic unit that rivals a lot of standalone aftermarket ECUs. The tuning software is also great, much easier to tune than some software out eg, eg wolf etc.
However if your tuner doesn't like nistune for whatever reason I would find someone else as your tune is only as good as the tuner, and if you tuner doesn't have experience with a nistune then I doubt his tune will be as good as someone who does them everyday.
Edited by Rolls
why then is a reputable sydney tuner telling me to steer clear of afm's because of 'reversion' problems? and 'over-fuelling' on gear changes/throttle closure? i have seen afms on massive power cars, but who am i supposed to trust?
ps: the stinger has temperature and barometric pressure compensation.
i dont like the idea of batch injection, but ive been told from two ecu manufacturers now that efficiency is only reduced by 5-10% and driveability losses can hardly be noticed. and at full boost it makes no difference since the injectors are close to constant cycle anyway.
Because unless you run a plumback BOV (all manufacturers do these days) the AFM will read double the air flow on gear changes due to the air crossing past the AFM twice. This is a VERY minor problem however and at worst will cause a tiny black puff of smoke on gear changes. The problems that a MAP sensor present are much more serious than a tiny tiny increase in emissions on gear changes or hard throttle to zero throttle transitions.
Who should you believe? Yourself.
Do some research and find out for yourself the pros and cons of each, asking here is a great start but ultimately you cannot trust anyone but yourself, so you should do as much research as possible before you commit to any idea.
Regarding batch injection mode, the difference in fuel economy is entirely due to your tuner however 10% is a big different, if you are using 14L/100km then if you switch to batch injection that is 15.4L/100km. You are buying a new ECU, there is no good reason to buy one that does not have 6 injector drivers and that has less than optimal air measuring sensors.
Edited by Rolls
I have run no BOV, recirculating BOVS and tiwn atmo BOVS and have NEVER had reversion problems or overfuelling etc with AFMS. and that includes stock AFMS on GTR, nismo AFMS on GTR, Z32 AFMs on GTR and a Z32 AFM on the silvia. if tuned properly and set-up properly there is no problem with whichever set-up you want to use.
and just like Rolls said the nistune can easily be retuned as many times as you like. I would seriously ring someone like envy who do a lot of them and ask them what features it does/does not have. it';s a very good option.
You will get air reversion if you run no bov but if tuned correctly you won't get the black puff of smoke or stalling issues that you get with blocking the bov off on a stock ecu. I know the redtop rb20s never had a bov and they were tuned to suit from the factory, no black puffs or stalling issues at all.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
