Hello,
I have some gauges and some pods for sale. All gauges are electronic (memory and warning) with the control box and wires. Some of the actual sensores are still on the car (Exhaust temp). Can be removed for buyer.
Condition: Excellent
Gauges: All 60mm
1. Oil Temp
2. Water Temp (Will sell with the radiator hose sensor and Samco hose)
3. Air Fuel Ratio
4. Exhaust Temp
Looking for $150 each and $175 for the water temp.
As for the pods: (From R33 GTS-T S2)
A-Pillar twin - $25 (Pick up only)
Dash Trippler - $25 (Pick up only)
Also have a Bride drivers side seat rail for S13/14 (Not sure what else it suits)
Has been modified to suit a bucket seat. Can be changed back to suit recliner.
After $70 for it.
Email [email protected]
Cheers
Edited by Nismo32
ill take the rail. pmed
Hey bud,
Im havig some problems with my PM's and my work computer (I cant reply).
Ill sort something out for postage and let you know. (Will be around $20)
Cheers
if your willing to post the dash pod il take it
il pay for post obviously
please let me know
Hello,
If its still here in a few days ill post it. But I am worried it will get broken during transport.
I can wrap it up but its fragile.
Ill let you know.
Cheers
thanks mate, if it fits its mine! ill probably pick it up aswell if thats okay
Hey bud,
I made a call, but we didnt make any progress.
Only sugestion is if your not far from Caulfield then you can come and see if it fits.
Cheers
Hey bud,
Cheers
no probs mate, ive sent you an email.
cheers
Billy
Edited by midnight
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
