Just looking for feedback on Moroso Oil Acculator's and if anyone has used one.
I don't particulary want to remove my sump atm to put baffles in to combat oil surge. I have have seen these though, any thoughts?
Moroso Oil Accumulator
Yeah we run one (canton) in the race car, setup with a solenoid. Cost was about 480 including solenoid and brackets etc...
Soon as the igntion is turned on it pre oils the engine (oil pressure before cranking) then it refills during run time. Any time the oil pressure drops below 40psi it discharges into the engine. Soon as you shut the engine down it shuts the solenoid off and hold pressure in the system for the next start.
I will post pics. We use it plumbed directly into the side of the greddy pump (as there is a dash 10 fitting there from factory).
Edited by URAS
Yep the pre-oiling is a good feature. Easier with solenoid though, as if you don't have the solenoid you have to pop the bonnet and open the ball valve before you start (and close the valve before you switch off so you have a shot for the next start.
Thanks URAS, some pics would be great.
