What guages do you guys find useful?
I currently have a boost gauge and an oil pressure gauge, both of which are obviously also standard on the dash to some degree.
What other type of gauges and what reason do you have them?
https://www.sau.com.au/forums/topic/29761-what-guages-do-you-find-useful/
In short, none, boost and oil is about all you want, extra tacho's are wank, if you want a shift light, just get a shift light, water temp can sort of come in handy if your keenish to do motorsport, because factory water temp guages don't really show temp varients of a couple of degree's..
other than that, stick with what you have, its all you really need.
I've got a sweet little temp sensor rigged up inside my cai partition. tells me the intake temps on hot days and gives me a rough feel for how the car should be performing etc.
it's connected to a blue EL light thingo which also has a voltmeter on.
loud stereo = need for a voltmeter. I'd like an ammeter too, but the feckin batterys in the boot, innit.
I'be got a hks boost gauge (reads up to 2bar) currently running 1 bar through the turbo and a greddy oil pressure gauge. I've found the gauges move much quicker than the stock ones plus being mounted on my a-pillar they are easier to read than the stock ones without taking my eyes off the road too much.
Me gots one of those units too.... bought it ages ago when I done my CAI.
All up I've got displays for
Rich/Lean bar Graph
Intake Temperature
Volt Meter
Boost
Speed alert
Revs
Digital Tacho
Shift Light
Trip Computer
Airflow
Knocking
Throttle
and more......
....love the blue Screen stuff :)
How much are they and where can I get me one? :)
Rich/Lean bar Graph
Intake Temperature
Volt Meter
Boost
Speed alert
Revs
Digital Tacho
Shift Light
Trip Computer
Airflow
Knocking
Throttle
and more......
do you honestly get much info from all those gauges though... i thought it would be easier to drive a car when u knew only select things. So you don't look at your volt meter bouncing while you're stereo's blasting and not concentrating on the road...
Then again those DEFI Link gauges are sweet as.
i only would need decent boost gauge oil pressure oil temp and possibly water temp...that about it the main two i would want is boost and oil temp.
Yepp, same here.
Boost gauge cause the factory one is slow and not in bar or psi :)
Oil pressue cause the factory one is slow and the sender can be dodgy.
Oil temp cause it give's you an indication on how the motor is and also can monitor it when cooling the motor down.
Water temp would also be a go'er if your doing some track work.
J
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
