Hey guys,
Well im not so good on the technical aspects of cars so was wondering if you guys could help me with my problem. My car (R33 gtst s1) is starting to react slowly. Flooring it from 1st and 2nd its fine. But when I cruise in gear and then floor it it lags. Its reading full boost but it gets like a second push after abit of lag. Is it my clutch ?
https://www.sau.com.au/forums/topic/297612-lagging/
Could be clutch (very likely), but could also just be general maintenence issue like spark plugs, crap built up in pipes etc...
Could also just be the 'flat spot' in the rb25's around 4500 rpm then it'll kick back in around 6000ish.
Or could just be operator error! :P
Edited by mosquitocoils
https://www.sau.com.au/forums/topic/297612-lagging/#findComment-4954121
if the clutch is slipping then the revs should rise but not your speed.
what sort of revs are you getting the lag at? is it always at a certain rpm or can it do it at any rpm? the r33's have a bit of a flat spot at 4500rpm when the VCT turns off. otherwise it could be your plugs or coils not coping that well with the sudden increase in fuel.
https://www.sau.com.au/forums/topic/297612-lagging/#findComment-4954772
Hey guys,
What gear are you cruising in?
4th / 5th?
Yeah you can floor it on 4th / 5th while cruising, but it won't be as effective as to down shift to a lower gear, like 3rd (power gear)...
https://www.sau.com.au/forums/topic/297612-lagging/#findComment-4954847
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
