PM FOR PICS OR CALL, MATT:0448887446 IF YOU HAVE ANY QUESTIONS, Most parts are still in vehicle but will be removed over the next couple of weeks
#ENGINE AND PARTS REQUIRED FOR A PROVEN 180KWATW+ CAN BE PURCHASED AS A PACKAGE IF REQUIRED(engine, ecu, turbo, injectors, intercooler, plumbing, BOV, fuel pressure reg, K&N Filter, braided fuel lines and fittings, remote filter mount and lines, oil cooler and lines) FOR $3000#
Evo/VR4 Twin spot Front Brake calipers, ADR braided lines, Evo RDA slotted rotors
(redrilled to 4x100 for lancer/mirage), Project MU type hc+ Pads: $400
Proton Rear Disc Brake conversion for lancer/mirage, Bendix Ultimate pads, ADR braided lines: $300
Mirage Whiteline Rear Sway Bar: $100
HKS Intercooler: $200
Intercooler Plumbing: $100
Haltech E6X ECU with GSR/EVO Adaptor Loom: $700
4 x R34 GTR Injectors: $200
Turbosmart StreetReg Fuel Press Reg.: $200
Evo 3 TD05-16G Turbo(bought new from ATS): $500
Toyo R888 15"Semi Slicks(Only 2 Hillclimbs old): $600
Toyo RS-1 15" Slicks(Only did 1 Time Attack): $700
Work Emotion CR 15" Alloy Wheels(new only 3 months ago): $800
CE Mirage/Lancer Ksport Coilovers(not even 12 months old): $700
Evo 2/3 Gearbox with Mech Front Diff (Rebuilt by CVAP Prior to purchasing): $1500
VL Turbo Fuel Pump: $50
Momo Safari Race Seat (Black): $500
CE Mirage Bolt in Half Roll Cage: $500
CC GSR 4G93T Engine: $900
Evo 1" Brake Master Cylinder: $100
Remote filter Mount+cooler & Earls Lines and fittings: $300
K&N Pod Filter: $25
Oil Catch Can: $50
Greddy Profec B Boost Controller: $300
CC 1.8lt Extreme Button Clutch: $100
Coolant res.: $50
HKS BOV: $100
CC GSR Driveshafts: $100
Cordia LH Driveshaft: $50
CC Coupe Driveshafts: $50
Can you be more specific on the tyre and wheels sizes? eg 195/50/15 15"x7" +20 wheels. Also how much tread is left other than 2 hillclimbs?
Whereabouts are you?
Cheers.
Sorry about that fellas.
All Parts are located in Adelaide
Toyo r888 205/50/15 approx. 70%+ tread left(cost $300+ each new)
Toyo RS-1 2x205/50/15 approx. 60%+ tread left and 2x195/50/15 approx. 80% tread left(cost $400+ new each)
Work Emotion CR rims are 15x7" +44 offset
Yes it is true, the car was on the market and hasn't sold as a whole, now it will be returned to a street car and all performance parts sold off. Need to move to make way for new project
Edited by no grip mirage
  • 1 month later...
whats the best price you would do for all these?
PM me if you wish :down:
front brakes and master cylinder are sold, you can have the rear disc brake conversion for $250 if your interested
interested !
what would i be looking at for postage to Mt Pleasant 6153 (WA)
interested !
not sure, will put items on a half pallet, but you will need to organise your transport. Sold a gearbox to a fella in Perth, cost him $60 to get it there.
  • 1 month later...
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
