Sound System Location
silbastian
 Share
Just wondering if anyone has any thoughts or tried having their sub woofer behind drivers seat floor rather than in them boot. Is there much gain/less boot rattle you reckon?
Reason i ask is, i hate having a big sub woofer in the boot because it leaves to no room for spare tires
given that a bass wave is rather long (in some cases 30ft!) and you have it right behind you - are you going to get 'best effect' vs having it far away as possible (IE boot.) ?
that wave needs to expand to really be felt/heard.
Boot facing in works well IF you seal of the box properly. Otherwise you get bass cancellation. I think thats the right word for it... basically the primary and secondary waves cancel each other out, which is why it generally sounds better that way when the boot is open.
The Crossfire Car Audio site used to have a good technical reference that explains the different subwoofer set ups for different types of woofers. (eg. band pass, isobaric, free air, sealed, ported, and some more elaborate types of woofers). It explained well how to properly install subs facing into the cabin in a sedan to eliminate the bass cancellation and reduce bass lost to panel vibrations. Basically comes down to how well you seal off the gap between the cabin and subs, and the boot.
How exactly were you planning on putting the sub behind the drivers seat?
You will also gain some response and volume from the cabin gain that you will get when in the boot.
buy a Porsche 911 then put the sub in front of you ,, bass in ya face. thru the air vents under the dash
did a LAMBO and 512 Ferrari that way, 8" solobaric in fiberglass box using the floor space under your feet on the passenger side. nice tight bass
but not lots of SPL to shake the ground with
you dont have to remove a spare to have good Bass,,, Im so tired of preaching that..lol
the skyline has more then enough room to be creative to get bass inside it without firing the sub into the boot which creates muddy boomy bass "in most cases " and rattles the hell out of them , Most Skylines have steel plates between the rear seat and boot anyhow but hidden between the rear seat and side panels is a big void. or more then enough room to port bass thru to the front , another choice , remove the rear speakers, port the bass thru the holes which will give you even more cabin gain as the wavelength of sound bounces off the shape of the glass backwindow = higher SPL
or port thru the back seat similar to using a 4dr seat with armrest /ski tunnel passthru to the boot . which gives a purer SPL, tighter bass.
a sealed, or bandpass box works a treat and can be sealed off from the boot area easy the GTT Sat Nav computer will need relocating but nothing else.
some GTR and cars with rear strut braces may need some tweaking to work but still not a worry
these are LEGAL ways, if your game to run the gauntlet of defects you can go crazy and cut the rear deck with ports and speakers.
putting a speaker in the floor isnt legal if you cut it or place the driving compartment in jeopardy of crashing in anyway(boxes that consume the drivers feet or passenger safety in anyway.
u dont need spare tyres
Spare tyres are for pussies.
not the space saver, just a spare 2 rims just incase i ever feel the need to pop my rear ones on-road.
i was gonna have the direction of the sub, facing the back window on an angle from the floor.
yeah i tried removing the rear speakers and having the sub going threw the holes though the fact is, i still had the sub in the boot which eh i don't like so much... previous owner put a 12" with a massive box which almost touches both struts. was thinking of maybe getting 8".
thanks for the replies all,
(ps. im not a bass pumping kid haha, i just want most usage out of my boot and also have some bass for kicks... nothing muzza)
Edited by silbastian
its easy mate, even a quality 8 or 10 will hit 130db or more with modest power and sound tight and punchy, clear
the box size doesnt need to be much bigger then a big shoe box either. any custom stereo installer should be more then capable of a design to fit your needs. and regain all of your boot back, your shocks will thank you and so will your performance of your car over the dead weight of a big box.
and spare tires ....sure beat walking ... or sitting by the road waiting for the roadside assistance guy to tell you your a putz for not having a spare in middle of whoop whoop(outback)!!!!...lol
get a flat with a chick in the car, she will wait!!!!!.........for the next car that pulls up to leave ya on the roadside alone..lol
our fitter at work made 140db with a single 10... :blink: easy as.
I had my Alpine Type R 12" (with ported Alpine box) in the boot of my 33. Rattled the absolute shit out of my car. Sounded good on the inside, but even on a relatively low volume the boot rattled like a mofo and was embarassing.
In my new Supra the box won't even fit in the boot (well, hatchback) of the Supra. It sits directly behind the driver which suits me fine because I HATE driving with a passenger behind me. Gives me the perfect excuse not to take more than 2 people at once. Sounds great now, especially with the windows open.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
