Stalling/cutting Out While Spooling
Sub_woolfer
 Share
pull out your spark plugs again and inspect them. that will give you an indication of whether it is a fuel issue. if they are black then it isn't a fuel issue but a spark issue. if they are a light colour then it is a fuel issue. if possible get someone to drive behind you and make it play up. if they see unburnt fuel coming out the exhaust when it missfires then you know it's a spark issue.
legend. will do
how much boost you running?
i have a similar issue and i thought its just the stock ECU fuel cut or R&R, if i reset the ECU it will be fine for a while....
how long was a while.. what did the final problem turn out to be?
he is running stock boost. he said it in an earlier post.
this brother from another mother.. been with the problem since the start of this pain the rear end hole!
its been raining in melbourne. when the spark plugs were changed over, i didnt replace the cover so i dont want to do too much work and, i dont think anyone'll be able to see whats coming out of my exhaust.
generally if the fuel pump is playing up it will usually only be in the high end where it starts to lean out. generally it should be fine at lower rpm as the fuel being used is very low so the pump should be able to flow well enough.
is it worth replacing? exactly as u say it does..
wouldn't hurt to replace it to be on the safe side, however if it isn't the issue then you have wasted a few hundred dollars. you would be best off putting the car on a dyno to get the AFR's checked to see if it is leaning out. that way if the AFR's are fine you can put the money towards finding out exactly what is the cause.
First time Ive had a drama with the car is today :laugh:.
Turns out mines doing same thing, But it does it at anything about 0+. shuders, hesitates, splutters, as if a cooler pipe has gone off :S
all new Gear, intake, gaskets, splitfires, tomei z32, about 80 dyno runs, never had an issue. today started it, driving to work.. this happening >.<...
wat the f!,.. PFC map?
I have no idea bro, sorry. Man, I'm sending the car to a dude in Melbourne that comes highly recommended. Supposed to go today but had a wedding I sorta forgot I had to go to. I'll go to him early on Monday. If he tells me the cars problem, I'll pass that on to you, or if you're in Melb. tell me and I'll give u his details.
the dude fixed it in 15 seconds. f'ing very good guy.
#1, the turbo we changed was boosting (or trying to at least) at 22psi,
#2, the afm was dodge so i replaced with the another standard one,
#3, the loom that sat in the afm was pretty shockingly crusty, so we changed that and he crimped it into place,
#4, the bov i had on the car was pushing a lot of what was in the pipes out, so the sensors got crappy readings and made it try and cut out,
just little bits and pieces. the dude did a massively good job, anybody in melb who wants serious work done to their car should go there.
i hope some of these steps help u in ur problem cuz.
good luck.
 Share
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
