Hella Tight M35
Chasey
 Share
Hey guys, im new to the forum but thought id post up some pics of my RS4 turbo M35. Im in NZ but running euro plates.
Running 19x10 AME rims at +5 offset, silk road coil overs, raiser exhaust.
X-member sits at 38mm from the ground.... suspension can go lower but as you can see its hard for the body to drop any more, also top arms hit on the body at this height.
Looks great and welcome to the forum Jordan.
I don't know how you drive around with 38mm clearance.....
Cheers
Andy
haha cheers, its my daily driver... i have to dodge every little bump i see on the road
Looks great! do you have any problems with the steering arms pointing up at that angle?
a mate of mine lowered his Pulsar to some stupid degree that he was having problems with the angle of the steering rack and arms
nah ive been told that its unsafe and the steering arms are on a wack angle and all that but to tell you the truth the car drives great apart from the top arms hitting the body (ive cable ties silicon hose on them) and the ground clearance. only thing ive had to replace was a CV boot
Looks awesome mate
What's on your agenda next
its just my driver to get me to work every day so im pretty happy as it is, i have other cars ive gone overboard on but i think this is the wrong forum for those lol
Welcome Jordan.
Great to see an RS colour-coded. Looks good!
Is that a Takero's Full Titan exhaust?
Dunno about the stance... if it was on Aussie roads anyway...
Always loved that style of wheel on M35's
Edited by iamhe77
Welcome Jordan.
yea i had all those black boring parts painted out :)
nah the exhaust is only the rear section, its got twin 4" tips... i had to source it from japan as i could find nothing for it
as for the stance ive had too much influence from sites such as hella flush and stance works
Any fender pulling / rolling to fit those bad boys? or just a lippin?
Looks very hot btw... certainly the look i will be going for once i find some decent offset rims
I have done nothing to the front gaurd except remove the screws that hold in the innder gaurds, i have a gaurd roller so i lipped the rear gaurds but had problems with the rear gaurds rubbing on the lip of the mag wheels so i had to push them out another 5mm or so :blink:
  • 1 month later...
I have done nothing to the front gaurd except remove the screws that hold in the innder gaurds, i have a gaurd roller so i lipped the rear gaurds but had problems with the rear gaurds rubbing on the lip of the mag wheels so i had to push them out another 5mm or so :(
WOW mate, just stumbled upon this now and... yeah WOW!
My new inspiration. I just bought a Masa rear wing and am about to order a JP Simple Style front lip and once I can afford it, some nice deep dished 19"s and then SLAM.
Are you running a Masa rear wing also? Looks very similar.
Edited by euroequip
hey thanx
um i had a masa rear wing but it was real similar to the factory one it already has on it so i sold it lol
Mike: It's my parents house
If I'm not mistaken its got Andrew Patteson Architects' signature all over it.
Nice looking car will look out for it but I'd never go there as I hate the low gait already and would source an ARX next for the go most places flow. Bilstein shocks and rear swaybar and front brakes modded of course but not lowered.
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
