Now available:
COIL PACK HARNESS - R32 GTST RB20DET - COMING SOON
COIL PACK HARNESS - SERIES 1 R33 GTST RB25DET- $100.00 delivered via express post.
COIL PACK HARNESS - SERIES 2 R33 GTST RB25DET - $105.00 delivered via express post.
COIL PACK HARNESS - R34 GTT RB2DET NEO - COMING SOON
COIL PACK HARNESS - R32 GTR RB26DETT - COMING SOON
COIL PACK HARNESS - R33 GTR RB26DETT - COMING SOON
COIL PACK HARNESS - R34 GTR RB26DETT - $115.00 delivered via express post.
COIL PACK HARNESS - 180SX/S13 CA18DET - $100.00 delivered via express post.
COIL PACK HARNESS - S13/S14 SR20DET - $110.00 delivered via express post.
COIL PACK HARNESS - S15 SR20DET - $115.00 delivered via express post.
All items are in stock in Australia and will be sent via express post.
CLICK HERE for more pics and details or to purchase.
Combine your order by purchasing a new set of Yellow Jackets Coils Packs and receive free shipping on the matching Coil Pack harness.
  • 1 month later...
  • Replies 217
Hi Paul
I remember a while ago there was some talk about Yellow Jacket Ignitors. Is there any update with these?
Thanks
I have them nearly ready for the R33 GTST but need to get the plug fitment better. They are currently too tight.
I need to get hold of some stock plugs or a stock ignitor so I can improve on this.
  • 3 months later...
S15 Yellow Jackets are now available for $340/set delivered.
Posted Image
Also available.....
Brand New Yellow Jackets T-Shirts for $25.00 delivered
Front print - Plain back.
100% pre-shrunk cotton.
Available in white only.
Sizes - Small / Medium / Large / Extra Large / Extra Extra Large
Posted Image
Now available:
Hi there!
Any news on whether the R34 GTT RB25DET Neo coil pack harness is available?
Unfortunately these arent going ahead as the manufacturers dont normally make them and if we were to go ahead Id need to order a minimum of 100 pcs. :(
Ok so I'll have to get them from Nissan I suppose, and connect them with the Yellow Jacket R34 GTT RB25DET coil packs (if you have any in stock)
Sorry I can help out with the harness. However, I definitely have the Yellow Jackets in stock and they will be sent out via express as soon as your payment has been received.
:cheers:
  • 3 weeks later...
  • 2 months later...
  • 4 weeks later...
Hi - can pm me the price for coil packs and harness? BNR32 GTR? - May want to get an item or 2 from your site as well... maybe can package the shipping? Please let me know.
Thanks!
Excellent seller and brilliant service - bought the harness - fits perfect - will definitely do business again! Cheers
Total price is $
Hello need a price for r33 gtr coil packs and harness posted to 2145
Total price is $540.00 including express post to 2145. :cheers:
  • 1 month later...
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
