Now available:
COIL PACK HARNESS - R32 GTST RB20DET - COMING SOON
COIL PACK HARNESS - SERIES 1 R33 GTST RB25DET- $100.00 delivered via express post.
COIL PACK HARNESS - SERIES 2 R33 GTST RB25DET - $105.00 delivered via express post.
COIL PACK HARNESS - R34 GTT RB2DET NEO - COMING SOON
COIL PACK HARNESS - R32 GTR RB26DETT - COMING SOON
COIL PACK HARNESS - R33 GTR RB26DETT - COMING SOON
COIL PACK HARNESS - R34 GTR RB26DETT - $115.00 delivered via express post.
COIL PACK HARNESS - 180SX/S13 CA18DET - $100.00 delivered via express post.
COIL PACK HARNESS - S13/S14 SR20DET - $110.00 delivered via express post.
COIL PACK HARNESS - S15 SR20DET - $115.00 delivered via express post.
All items are in stock in Australia and will be sent via express post.
CLICK HERE for more pics and details or to purchase.
Combine your order by purchasing a new set of Yellow Jackets Coils Packs and receive free shipping on the matching Coil Pack harness.
  • 1 month later...
  • Replies 217
Hi Paul
I remember a while ago there was some talk about Yellow Jacket Ignitors. Is there any update with these?
Thanks
I have them nearly ready for the R33 GTST but need to get the plug fitment better. They are currently too tight.
I need to get hold of some stock plugs or a stock ignitor so I can improve on this.
  • 3 months later...
S15 Yellow Jackets are now available for $340/set delivered.
Posted Image
Also available.....
Brand New Yellow Jackets T-Shirts for $25.00 delivered
Front print - Plain back.
100% pre-shrunk cotton.
Available in white only.
Sizes - Small / Medium / Large / Extra Large / Extra Extra Large
Posted Image
Now available:
Hi there!
Any news on whether the R34 GTT RB25DET Neo coil pack harness is available?
Unfortunately these arent going ahead as the manufacturers dont normally make them and if we were to go ahead Id need to order a minimum of 100 pcs. :(
Ok so I'll have to get them from Nissan I suppose, and connect them with the Yellow Jacket R34 GTT RB25DET coil packs (if you have any in stock)
Sorry I can help out with the harness. However, I definitely have the Yellow Jackets in stock and they will be sent out via express as soon as your payment has been received.
:cheers:
  • 3 weeks later...
  • 2 months later...
  • 4 weeks later...
Hi - can pm me the price for coil packs and harness? BNR32 GTR? - May want to get an item or 2 from your site as well... maybe can package the shipping? Please let me know.
Thanks!
Excellent seller and brilliant service - bought the harness - fits perfect - will definitely do business again! Cheers
Total price is $
Hello need a price for r33 gtr coil packs and harness posted to 2145
Total price is $540.00 including express post to 2145. :cheers:
  • 1 month later...
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
