Now available:
COIL PACK HARNESS - R32 GTST RB20DET - COMING SOON
COIL PACK HARNESS - SERIES 1 R33 GTST RB25DET- $100.00 delivered via express post.
COIL PACK HARNESS - SERIES 2 R33 GTST RB25DET - $105.00 delivered via express post.
COIL PACK HARNESS - R34 GTT RB2DET NEO - COMING SOON
COIL PACK HARNESS - R32 GTR RB26DETT - COMING SOON
COIL PACK HARNESS - R33 GTR RB26DETT - COMING SOON
COIL PACK HARNESS - R34 GTR RB26DETT - $115.00 delivered via express post.
COIL PACK HARNESS - 180SX/S13 CA18DET - $100.00 delivered via express post.
COIL PACK HARNESS - S13/S14 SR20DET - $110.00 delivered via express post.
COIL PACK HARNESS - S15 SR20DET - $115.00 delivered via express post.
All items are in stock in Australia and will be sent via express post.
CLICK HERE for more pics and details or to purchase.
Combine your order by purchasing a new set of Yellow Jackets Coils Packs and receive free shipping on the matching Coil Pack harness.
  • 1 month later...
  • Replies 217
Hi Paul
I remember a while ago there was some talk about Yellow Jacket Ignitors. Is there any update with these?
Thanks
I have them nearly ready for the R33 GTST but need to get the plug fitment better. They are currently too tight.
I need to get hold of some stock plugs or a stock ignitor so I can improve on this.
  • 3 months later...
S15 Yellow Jackets are now available for $340/set delivered.
Posted Image
Also available.....
Brand New Yellow Jackets T-Shirts for $25.00 delivered
Front print - Plain back.
100% pre-shrunk cotton.
Available in white only.
Sizes - Small / Medium / Large / Extra Large / Extra Extra Large
Posted Image
Now available:
Hi there!
Any news on whether the R34 GTT RB25DET Neo coil pack harness is available?
Unfortunately these arent going ahead as the manufacturers dont normally make them and if we were to go ahead Id need to order a minimum of 100 pcs. :(
Ok so I'll have to get them from Nissan I suppose, and connect them with the Yellow Jacket R34 GTT RB25DET coil packs (if you have any in stock)
Sorry I can help out with the harness. However, I definitely have the Yellow Jackets in stock and they will be sent out via express as soon as your payment has been received.
:cheers:
  • 3 weeks later...
  • 2 months later...
  • 4 weeks later...
Hi - can pm me the price for coil packs and harness? BNR32 GTR? - May want to get an item or 2 from your site as well... maybe can package the shipping? Please let me know.
Thanks!
Excellent seller and brilliant service - bought the harness - fits perfect - will definitely do business again! Cheers
Total price is $
Hello need a price for r33 gtr coil packs and harness posted to 2145
Total price is $540.00 including express post to 2145. :cheers:
  • 1 month later...
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
