FOR SALE
TRUST T78-33D
Manifold
External Gate 50mm
Dump Pipe
Inlet Pipe
Twin Entry Filter
2 x K&N filter
Turbo has done less than 2000km since new and made 504hp @ 20psi. Awesome setup for any GTR, just bolt on and tune.
$3800
Also selling Power FC D-jetro with Apexi Boost controller kit with tune ( computer purchased new at the same time)
$1400
Will also sell near new SARD 800cc injectors if anyone want to the full package to bolt on for a turn key 500hp at 20psi ( just add your own intank 044). Give us a call only to happy to help.
Seller: Nigel Brown
Phone: 0417 981 596
https://www.sau.com.au/forums/topic/297780-trust-t78-33d-kit-for-sale/
Sorry Guys cant pm anyone yet as i dont have enough posts. ( will keep posting questions here )
Reason for sale is going to a larger setup.
Kit was on a std RB26 and loved every psi it had to offer.
FOR SALE
TRUST T78-33D
Manifold
External Gate 50mm
Dump Pipe
Inlet Pipe
Twin Entry Filter
2 x K&N filter
$3800
$1400 (SOLD PENDING FUNDS)
Seller: Nigel Brown
Phone: 0417 981 596
Does this single set-up require the power-fc de jetro? i have power fc with z32 afm an all the good bits, was curios if that mattered? an also it wasn't a lag monster was it? wat rear housing? wen was full boost? im running a fully built rb26 tomei engine basically wit gt2860 -7 :S they aint gonna cut it but if you could answer those questions you may have yourself a buyer :)
Bye the way nice engine bay mate!
Does this single set-up require the power-fc de jetro? i have power fc with z32 afm an all the good bits, was curios if that mattered? an also it wasn't a lag monster was it? wat rear housing? wen was full boost? im running a fully built rb26 tomei engine basically wit gt2860 -7 :S they aint gonna cut it but if you could answer those questions you may have yourself a buyer :laugh:
Yes the Trust twin entry suction pipe was designed to fit directly onto Z32's and run a power fc.
Turbo was building boost by 4K and pulling hard over the mid 4K region. Did vary a little and felt more responsive down low when under high load. Those figures where from straight line driving. Turbo never drops off boost between gear changes and was a great setup on some tight and flowing hills roads.
Not sure what housing size is as the numbers on the exhaust housing don't correspond to anything that makes sense, but ive gotten these numbers from the ID tag.
Make: T78-33D
Serial No: B276501
MFD No: 49175-02020
Hope this helps and it will be a very strong setup on a built engine, and thanks for the kind words on the engine bay.
Cheers
Nigel
Hey Mate, i will speak to my mechanic today, being monday the 13th an see wat he says but is it possible to grab your phone number? currently overseas in iraq atm that is all but i am from perth car is currently bein built as we speak an would be an interesting upgrade whilst the engine is out, so im interested but i will have to get back to you asap after i ring my mechanic.
Cheers Korey
Cheers Korey
So now i feel like a dick lol, seen ya number will give you buzz first thing monday morning 14 dec, you should have an answer buy the end off that day mate!
Cheers!
Cheers!
if nigel doesnt answer dont panic , i think he is overseas too atm ,
ps ive been in this car and its a weapon !!
Thanks Marty (mxracer),
I'm currently in China for work till the 28th of this month with no mobile coverage.
Please PM me or add to the post with any questions and ill keep you all informed. Turbo will be available for pick up or post from the 29th.
Turbo is sold to a Perth buyer, but i cant confirm this until i arrive home.
Thanks
Nigel
Ok so does this mean that everything bar the turbo would be avaiable atm? cause some1 bought the turbo itself? i guess ill have to wait to you confirm it or not.
an my car is a weapon to lol
Thanks
Nigel
So if the turbo is sold would you be willing to sell the remainder being the:
Manifold
External Gate 50mm
Dump Pipe
Inlet Pipe
Twin Entry Filter
Cause i will snap them up as soon as you arrive to australia without a doubt!! My mechanic says it will be perfect an on my built engine will push numbers beyond 600hp at the wheels, but if the turbo is sold that is no probalem still the remainder like i said above is more then ample.
Cheers Korey
  • 3 weeks later...
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
