If you replace valve seals, usually they bed themselves in for a little bit.
You'll get a bit of smoke for a while (or so im lead to believe, i could be wrong) then it goes away after a while...
do you know the condition of your turbo?
cos it could be the turbo bearings.
ahk hopefully thats the case and they will maybe take a couple days to bed in then :) seeeings i drove it for the first time this arvo ey! umm turbo is a hks 3037 gtpro being going for about 18mnths on 15psi. so i hopefuly doubt its that. had it off neways no oil newhere :0
yeh doesn't sound like its your turbo, great choice btw! those turbos are the bee's knees!
i sat give it at least 1000 kms and see where your at from there.
maybe try a compression test to see if anything is abnormal!?
cheeers bro!~ yea its the shit! i love it i made 283kw in 40+ degrees on 15psi :)
compression is all sweet had the bottom end built fully a year ago wen i did the conversion :)
could a shitty lifter cause it? coz there is a noisy one (effing loud) as of today ???
im gunna put some of that lifter free stuff through tmoz and see wot happens
