Hello SAU,
My R33 GTS25T has been out of action for 2 or so months now.
I will start from the beginning, One day I was idleing my skyline at my house and was sitting infront of it.
Randomly I heard a 'tick' noise and the engine stopped, since then It hasn't started.
It cranks over but it won't start it, The spark plugs are firing and had them replaced recently after the car died.
Replaced the CAS and Cleaned my AFM.
The ECU has the error code of 13 which is apparently the Coolant Temp Sensor.
Earlier before the car broke down I had to bypass the coolant pipes that goes to the heater because it was leaking into the passanger side.
I dunno what to do, I am stuck driving my Hyundai Sonata 4 cylinder that stalls all the time and not to mention its FWD.
Thanks SAU hope to hear from you soon.
https://www.sau.com.au/forums/topic/297786-broken-r33/
was the 'tick' like the sound of flicking a switch? it may have been a relay or fuse blowing. i'd go through the fuse box and check them all.
Hey thanks for the reply, It came from the front of the engine I have checked all the fuses under the dash.
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4956895
there is a fuse box in the engine bay (drivers side near the strut tower) that has all the relays, etc in it. my guess is that one of them is gone. if you do find one blown, then don't just buy one to replace it, but buy one as a spare, because there is a small chance it will do it again if there is a short in the system, in which case you would need to find the short before installing the spare one.
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4956969
Thanks for the reply, Will have a look when I get home from work and will post back here on the progress.
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4957373
did you recently wash the engine? water can eventually stuff the sensor I reckon...
if the error is for the coolant temp sensor try replacing the sensor, I had an intermittent issue with coolant temp sensor, where eventually the car would not start replaced the sensor and everything was fine, sensor cost $20 from Phat lavish on here who sometimes (actually quite alot) strips cars down for part selling...
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4957458
Yes I did wash the engine. Apparently I cannot message PhatLavish until I have posted 10 times, I am willing to buy a new sensor.
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4957530
have a check around at some wreckers any one with a shot rb25 or wrecked 33 will have one...
you know where it is? from memory its just above the top radiator pipe where it connects to engine... electrical plug goes straight down into it, its sitting right up on top, the easiest sensor to get to. be sure when replacing it you top up the coolant when you screw it back in to avoid getting an air bubbble in your cooling system...
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4957868
I live in geraldton, Nowhere in town that has wreaked Skylines, After this post though I can message that guy the get a new sensor (Because I now have 10 posts).
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4959171
keep in mind that you can post online on the auto wreckers part request sites (eg. www.carsparefinder.com.au)
Wreckers are quite happy to post parts to you...
I put a request in for a D40 tailgate and got a reply from three wreckers from all over the country the very next day...
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4960760
How long did the car run for after you washed the engine? From what I remember you need to reset the ECU to show up all error codes. When the car is running for a bit these error codes get cleared one by one. You will keep getting the temp sensor error code because the car hasn't warmed up so that it can be cleared. The ECU codes are only a rough idea on what is wrong.
The ECU maybe outputing another code after the temp sensor one.
Also check you didn't damage any cables when you bypassed the cooling pipes and check not coolant reached the ECU in the kick panel area.
One more question, how long was the car running ok for before it wouldn't start anymore?
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4965701
after you washed the engine did you dry any water out of the coilpack valley? if not then i'd say you've fried the coils. they will arc out something major when there is water in there (know from experience) and i would assume that if you don't dry it out the coils would just keep arcing out and end up creating weak spots where they will continue to arc out even when dry.
also the car should run even without the coolant sensor plugged in.
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4967311
Ok this morning I started my car, but it would only sit at 500 revs and drop and go back up, did that for a minute, I applied accellerator and it cut out and wouldn't start? Does this info help in diagnosing the problem, thanks.
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-4982640
  • 3 weeks later...
Bump +1
It is still having problems.
:D
https://www.sau.com.au/forums/topic/297786-broken-r33/#findComment-5010887
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
