Lewis’s R34 Fourdoor Build Thread
went on the dyno yesterday for a remap and a cleanout. Really happy cars running great now and made 210.9kW @ 168km/h. :laugh:
Looking at the torque graph its a bit weired, silly auto's. instead of it increasing slowly as like a power curve it's high then drops it all off and then goes back up again.
Hmmm thats some good power, be stoked if mine gets near that when i finnally get the NISTUNE put in.
Love that exhaust to, so want.
Thanks mate :banana:
So the volks are getting picked up on Sunday arvo and these are my temporary wheels........but I think are going to slightly more permanent.
18x9 +30 & 18x10 +18 front and rear rapped in Kumho Ku36’s
They sit pretty nice, but need to get the guards rolled and lift the rear slightly so that’s happening tonight so its sweet for the SAU-SA Dyno Day.
Failing that though nothing a few degrees of negative camber can’t fix
A few little updates, I ordered myself a KKR Black intercooler kit today 600x300x76 so should arrive later this week ready for Saturday to get hooked up and also found a silvertop r32 actuator too with an 11psi spring which is better than the weak as standard 34 one. Then the following weekend going to do the 100k major service and get her running sweet.
We have a problem though...
The few weekends ago I took my gf and a couple of her friends on a wine tour in Malaren Vale, was a really nice day until we pulled into this one of the wineries driveway (had a horrible peak really sharp angle). Went over it thinking should be sweet anyways bottomed out over the crest of the driveway and heard a large bang, pulled up and opened the bonnet to hear a violent hissing sound so turned the car off and the hissing persisted. Now the only thing it thought that would be holding air pressure with the car off is the air conditioning system. But that works fine hot or cold and it was coming from around the turbo right hand side of the engine bay. So I’m really stummed, i haven’t had time to get it on a hoiste to check the front pipe (might have cracked that) but a few weeks ago we had the sau:sa dyno day i only made 161kw.
Then going to take it up to dex at garage 7 for him to have a sus and try find out what might have happened and to get another tune with the fmic n new actuator & 12pound instead of the 10 its running now.
New addition for the 34 arrived yesterday.....KKR Stealth series tube & fin front mount intercooler kit. Its all black! :)
I plan on getting it in ether this weekend or next, so keen to see how it looks behind the front bar :)
Just picked these up...after a 2 and a half month wait for them, got send the first set without a locknut key :P
but all good now they took them back n sent me a new set just took forever...
  • 1 year later...
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
