For Sale:
1989 R32 GTR - Silver
Purchased in 2004 - Self import ex Japan. Drove the car for a few years and then parked it (last registered in 2006) I have had this car sitting in my garage for about 3 years contemplating engine rebuild... I decided at the beginning of this year I would go ahead. As it turns out, just when all is done my missus tells me JNR is on the way... sell the car!
RACEPACE have just completed a fully built RB26 and reco'ed my gearbox... I just spent a small fortune on the car (receipts provided)
402.6 RWKW on Dyno last Friday 20/11/09
Car has some cosmetic panel damage on passenger door skin and rear 1/4 panel.
I will list as many things as possible but I may miss a few aftermarket goodies;
Big Single - T78 Turbo
TRUST Intercooler
Apexi - Power FC + H/Controller (Fully tuned by Ben @ Racepace)
TIEN HA Coilovers
TRUST Oil Cooler
ProfecB Boost Controller
Sinnea 2 piece 18 x 10 Deep Dish Rims - 90% Rubber (less than 5000Km on tires)
HKS N1 Exhaust Cat Back
Custom Headers / Dump Pipe / CAT
Usual Gauges and so on...
Asking $29000
Heaps more pics (new) that I can send or direct you to
Contact me via SAU and provide phone number or I will send you mine via PM
Robin
DYNO_NOV2009.pdf
Edited by RTFGTR
hey mate can you please email me some more pics of your car including some inside shots. also can you include a brief list of the parts used in the rebuild? send to [email protected] cheers mate.
Off line all weekend, will send all requested info tonight after work... busy today =(
** Same applies to all PM's received. I will action all and reply tonight.
Thanks
Email sent
For Sale:
Racepace RB26 Stage 1.
o Block/Head inspected, water and oil gallery plugs removed, hot-tanked, crack and pressure tested.
o Block bored and honed (strainer plate), decked to correct compression height, crank tunnel line honed. Strengthen block weak points (similar to N1 block)
o Oil galleries modified, tap galleries, fit threaded plugs, modify water galleries, new welsh plugs.
o Conrods resized, bushes replaced and individually honed to suit piston pins.
o New R34 Crankshaft, rotating assembly fully balanced.
o Race Pace Custom Forged Piston and ring set.
o Nissan N1 Oil Pump (Modified), Nissan N1 water pump.
o Race Pace special main and big end bearings.
o Cylinder Head: Replace valve guides / stem seals, cut seats, face valves, match chambers, surface, re-shim.
o New cambelt, tensioner and idler pulleys, metal head gasket, new seals and new thermostat.
o Fully blueprinted, block painted and precision assembly.
TRUST Intercooler
TIEN HA Coilovers
TRUST Oil Cooler
Asking $29000
Robin
Some rebuild info for the RB added
Hi, Can you pls send pics to [email protected], including engine bay, interior, damaged panels and anything really.
Thanks, and im a serious buyer, cash ready for the right car.
Also, what was done to g/b?
One of my fav GTRs which deserves a good home. The noise this thing makes and nice low stance with mesh wheels is a great look! Best of luck and shame it has to find a new home :D
Thanks Roy - Thanks GTR 94 for your kind words about my baby (The GTR that is)
Some good times had back in the day and a damn shame it has to go... especially after hanging onto it for 3 years in the garage dreaming of rebuild.
It will be back at Racepace for a few lil RWC things this week then registered hopefully in a few weeks time so I can enjoy a few more summer drives before it's SOLD
(Would love to do another track day now I have 400+kw to play with but just can't risk anything going wrong :) )
  • 4 weeks later...
Price Drop $27000ono
0447686478
OK only 8 to 10 weeks to go B4 my baby girl comes into this world and nothing but rim kickers and pic junkies interested so far... I'm CRAZY but;
PRICE DROP to $23000 firm as is.
Just spent in NOV09 $18K on the RB26
0447686478
Robin
Can you post pics of damage.
Do you have an estimate to fix it?
Cheers
alex
Hi Alex,
Depends on how you fix it... bog and paint about $800 if you do it the way it should be done... $2200
pics of damage and car at http://s782.photobucket.com/albums/yy102/Robin_Feb/
Regards,
Robin
Hi Alex,
Regards,
Robin
CAR IS SOLD
:P
Let me say it sold cheaper than my firm price.... dude has grabbed the buy of the year
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
    • As above, replace as many as you can afford. If anything, due to old age.
