  • Replies 40
has anyone got it? has anyone used it? has anyone seen anything glaringly wrong with it???
i hear mixed things but it seems to keep advancing - canyou still not get SBS on it?
Really, for those with the old PS are going to get pissed at only 60-80GB to work with.
The new PS sux - yeah 250GB but no backwards compatibility...
ABC is available on the new software update on PS, for those who are fans of ABC...
PlayTV is getting high remarks from where i work, IT DIstributor, so all thumbs up here...
Cheers,
Andrew.
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4957012
Bought mine yesterday (thursday) just installed it along with a new 500gig hdd, looks pretty good so far, will let you know if i find any problems.
The sbs problem was only on the euro models and was only a software issue as they do not use that frequency over there, from what i have read any one in aus who has bought a euro model just needs to update the software and you can get sbs.
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4958088
And for those who dont have a ps3 i believe they are currently including play tv with the new 250gig models, assumed that would do that sooner or later just thought they would leave it as an option for a while first.
And the only problem i have with it (same as the ps3 on its own) is the fact that it is now a total multi media centre but you still need an outside source (and different remote since the ps3 is bluetooth) to adjust the volume.
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4958090
so its now time to buy a PS3 bluetooth remote?
Yes, play tv also comes with a new overlay for it with extra labels on the buttons you use for play tv.
Couple of other things i found last night that i didnt like like:
When flicking through the channels you come to the end of the list it dosnt go back to the first one, you have to go back down through the channels to get back to the first one.
Does not seem to have an option to record other shows in the guide with the same name, just gives you the option to record that time and channel daily weekly or just once, great for something like neighbours but for car shows on ONE that are not on at the same time every week you have to go through the guide and record them all seperately.
You cant set a default setting so it automatically starts recording early and finishs a little late so you dont miss the start or end, you have to do it for every show you record.
You cant rearrange the channels so you flick through in the order you want.
They are all just little things that hopefully will be fixed with software updates in the future.
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4958770
i would've hated to have bought a 250gb ps3 just before playtv was released since they are now bundling it. wow sight and sound have the bundle for $568, but dick smith have it with the blue ray remote for $588. they are the only 2 i have looked it, LOL
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4980606
An issue I have found is that if you have not changed channels since another show has started, it will not refresh the channel info that comes up until you actually click to go into that channel. Gets really annoying.
Also the fact that a few shows I was recording started and finished 10 minutes late got annoying, but figured it out soon enough. Luckily for me SBS started and finished on the dot, did not get an ad at the start nor finish...was great.
I have a playtv on lay-by at my work (target). If anyone wants one I can give it to them for 130 which is what it cost me. Pretty decent since cost price is $129 as far as I'm aware. Dick Smith stock it for 148 but you'd be hard pressed to find one in stock anywhere at the moment as most have sold out, and deliveries (for my work at least) aren't due til mid to late January if that.
Send me a pm if anyone wants it for $130.
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4981682
The channel info is a bit of a bitch, instead of just going through the info and keeping it on the same channel you have to go through every channel.
I found that only channel 7 is 10 minutes late every night, dont know if its them being shit or its just to piss off people recording, or maybe its hoping that if people watch there show and miss the first 10 minutes of the show they wanted to watch on another channel they will just leave it on 7.
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4982017
my set top box is like that for both the epg and the info bar which shows what is on now and on next. mum's set top box though will bring up the epg for all channels at once but if you actually want to read about the show it will change channels as you select a different channel on the epg.
for the people that have it, if you bring up the epg does it just show what is on currently and then everything following it or does it show the whole day? my set top box shows the whole day and doesn't automatically jump to the current time so you have to scroll down to the current time. also mine won't let you scroll the description (what happens on the show, not the name, although sometimes that would be helpful too) of a show if it takes up more than the small space provided, yet another brand of box i have used does. not sure if mum's does or not as i've only used it once or twice. does playtv allow you to scroll through the description of the show if it is too long?
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4982054
Just checked mine, when you bring up the epg it shows from the start of the current show and two hours forward, you then click on a show and it comes up with an option menu to go to that channel, record or view info, when you view info it brings up a box that is full screen so there is plenty of room for a full description.
https://www.sau.com.au/forums/topic/297825-playtv/#findComment-4982109
  • 3 weeks later...
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
