Hi Guys.
I got 2 RB30 short bloks from Australia, and wanna build a RB30/RB25 into my Stagea RS4, but i am not sure i have all parts and, and how to build the buttom of the engine.
The RB30 shot blok is rebuild, so my new wiseco pistons in size 86.5 fits, i have all the bearings, the HX version from ACL, my crank is polished, and new gaskets.
I have a RB25 buttom with 4WD and, a RB26 buttom from a R34, witch one is the best to this engine, my goal is 800+ hp.
My RB25 top, is a RB25DET, it is ported, and i have Tomie Pro cams, solid lifters, timing belt and adjustable cam wheels..
New oilpump from Nismo, new waterpump, big plenum, single turbo manifold and a Garrett GT45.
The adapter-plate i have to use to assamble the RB25 top and the RB30 buttom, where can i buy that, or is it better to build by that my self.!
Other things i need, before i can assamble the engine.!
Best Regards.
Jorn Petersen
Denmark.
https://www.sau.com.au/forums/topic/297851-rb30rb25-questions/
there is a thread dedicated to the 4wd conversion at the top of this section.
you can pick up a 4wd adapter plate from proengines he is a member on this site.
Hi TiTAN and thanks
Is the adapter-plate the only thing i need, to attach the RB25 buttom the to RB30 blok.!
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
