Which stroke would you prefer?
55 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hang on, what we're talking about is a crankshaft for an inline 6, right?
By that logic, _those_ guys that have copied the relevant Nissan dimensions (e.g. rod-rod distance) should not be doing that; and Nissan should not be selling a 4-stroke motor with overhead cams, and ...
Far better to pool all that knowledge; get what works, and use that as a basis for future refinement. Kind of what we use the forums for. Stop people repeating the same mistakes.
R&D is about being first-to-market or improving on an existing design to make sales. I bet the very first <foo> crankshafts were simple copies of Nissan's cranks with some minor changes.
Then more technology from e.g. the racing world was imported. Did HKS invent the counter-balanced crank? No. How about knife-edging? Nup. Do some of their cranks have those features? You bet.
Have they got an advantage for being first- or best-to market? Yes. Should that advantage continue in perpetuity? Hell no.
If the design _can_ be patented (good luck doing that with a crankshaft unless it has some completely new feature) then the innovator gets some extra benefits other than actually being in the market.
Let's face it; there are only so many options for crank dimensions, design, and materials choice for the RB26. Most of those options would already have been explored.
A good crank will incorporate the good and leave out the bad. I say bring on more people making quality crankshafts.
Regards,
Saliya
I think it's more the chineese copyin, claiming it's a "HKS" yet it's made out of very low quality steel and is bent from the factory... That's the issue.
Nothing wrong with copying, so long as you're not claiming it is something it isn't, or trying to make it look like them.
77.7 please!
just jap sell a brand spanking 26 crank for $1190
but If a stroker crank was available Id get one for sure.
Edited by Mr. Untouchable
77.7 please!
the stock stroke crank will come in about the same as the above price, the 77.7mm will be dearer but not much.
count me in for a stocker than in a couple months, how long away do you reckon they'll be?
Well it's sounding very tempting then!
  • 1 month later...
  • 9 years later...
Well this thread seems to just have faded away, 73.7mm full counter crank would spin up so fast and redline around 9500 - 10?
What became of this, has any one used a 73.7mm crank?
Im looking for a Full counter normal stroke crank.
https://www.junauto.co.jp/products/crankshaft/index.html
https://www.hirano-tire.co.jp/tomei/rb26/rb26-1-5.html
http://www.nitto.com.au/products/crankshafts.html?vehicle=nissan
https://nlgroupautoparts.en.alibaba.com/product/60813976018-805081960/Top_Quality_Billet_Racing_Crank_shaft_for_Nissan_RB26_RB26dett_Engine_Crankshaft.html?spm=a2700.icbuShop.41413.19.746a66b5HATbqZ
Have you seen this?
JUN Auto is about an hour from my house:)
TOMEI has had some internal conflicts resulting in a split between both founders, a subsequent business opened called Real Speed Engineering or RSE , oddly enough since both parties are were founders both parties share the patents LOL
I was looking at some of their cams a while back and was wondering where they popped up from. Ended up getting some custom Camtechs out of NSW made up instead to feed the EFR.
So has one partner started RSE and the other still running Tomei?
You should put a Jun 2.8 kit or the famous 2.7 seeing as how they are so close, they can do your block also and set it up perfect!
I'm about 5 hours drive away from you by the look of it.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
