Hi guys, Today i tryed to re-rego my car and failed, so i called up the rta and asked why, btw i did get sent to the EPA inspection station located in East Roseville behind the caltex before the Roseville bridge. But i passed and my exhaust was fine.
After speaking to the rta, i was informed i had an outstanding defect but i just couldnt figure out what it could be, i rang up the station where i had my skyline inspected and they said apparently the nose reducer on my 100% complete standard exhaust system and muffler was a defect?.
Baically that is bs right up, the r33 stock exhausts all come with a stock built it nose reducer, but the weird thing is the first time i was defected the car passed, but this time the guy from last times parnter did it, he goes buy the name of Kevin, he decided it would be a good idea to make up this bullshit excuse that apparently this isnt stock on skyline.
After a while i couldnt be bothered arguing with the guy, soo i take my car to my mechanic who and the documents and ask him to call this f&*kwit to see if he can talk any sense into him.
So i come back to pick my car up today and my mechanic said straight up "hes a f*&king idiot" its a stock part of this car and its not doing shit anyway, basically hes trying to stinge more money outta me and make up bs to make my life more of a c*&nt. Basically i have beem frauded by the EPA spection garage at East Roseville.
In the end its not worth arguing, but im still pissed i have to pay the 60 dollar inspection fee when its this dumbC*&nt Mechanic doesnt no what an exhaust looks like.
So if anyone lives on the northern beaches or north shore, and u have been defected by epa, DO NOT take ur car to East Roseville inspection station, and stay away from a shithead called kevin.
THANK YOU
yea heard bad shit there 2, iu guy i no went there 4 a blueslip, he ended up leaving with a massive amount of defects, supposively the guy defected him for no coolant lines goin to the throotle bodie , wtf ?
Couldn't understand most of your post, but if the silencer is removable, it is not legal. must be a permanant silencer.
Also, slandering a company is against forum rules.
ya that was my first thought aswell, but he doesnt say who the mechanic was or the company of the dodgy mechanic....
As for roseville epa comments.... yeah its borderline from what i can understand of his comments
Boys Boys Boys!!!!!! . f**k the northshore for Blueslips . those wogs have had there fingers up there arse's for the past 15 years . im on the other side off the bridge . Payless Tyres in forestville.
Give us a call !!! 9975 2660 . we will hunt down ones cheaper than what they have
ha ha ha ha haha ha a aa h ah !!!!!!!!!!!! rofl!
just makes up the rules as he goes huh
yah he means the butterfly valve that opens depending on rpm or throttle position, i forgets which one
definitely stock kit on r33 exhaust or possibly a factory option? oem either way
my old r33 came with a stockie exhaust, 93 model series 1, twin tip & the butterfly valve was only on the one tip from memory, designed to open up depending on revs or throttle position(forget which one), like I said it's possible it might have been a factory option or changed in later models
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
