Here is our selection of brand new AUTOBAHN88 Oil Cooling items.
- The link next to each item below will take you to our site where you can view pics & details and where you can purchase and pay via paypal with our secure online checkout system.
OIL COOLERS:
CAOC01B-DELUXE 10 ROW OIL COOLER & RELOCATOR KIT - AU$360.00 shipped - Addtocart.gif
- 3PC STAINLESS STEEL HOSE(AN8 )
- AN8 ANODISED RED & BLUE FITTINGS
- 10 ROW GREDDY STYLE TANK(250x130x50mm)
- REMOTE OIL FILTER RELOCATOR ADAPTOR
- HOSE LENGTHS(3): 160cm - 120cm - 100cm
CAOC01B-DELUXE 15 ROW OIL COOLER & RELOCATOR KIT - AU$380.00 shipped - Addtocart.gif
- 15 ROW GREDDY STYLE TANK(250x190x50mm)
-2PC STAINLESS STEEL HOSE(AN8 )
-AN8 ANODISED RED & BLUE FITTINGS
-REMOTE OIL FILTER RELOCATOR ADAPTOR
-HOSE LENGTHS(3): 160cm - 120cm - 100cm
(everything as pictured above minus the core)
- 2PC STAINLESS STEEL HOSE(AN8 )
- OIL FILTER ADAPTOR
-HOSE LENGTHS(2): 160cm - 120cm
- HOSE LENGTHS(2): 160cm - 120cm
- AN10 SIZE
- 250x130x50mm
-15 ROW GREDDY STYLE TANK
-250x190x50mm
CAPP05 - OIL TEMP/PRESSURE GAUGE SENSOR ADAPTOR - AU$50.00 shipped - Addtocart.gif
OIL COOLER FOR POWER STEERING/TRANSMISSION/DIFF - AU$130.00 shipped - Addtocart.gif
FEATURES:
BLACK 6 ROW OIL COOLER
COOLER SIZE: 26cm x 8.5cm x 3.5cm
HIGH QUALITY AN6 PLUGS
AN6 NYLON BLACK BRAIDED HOSE (2 Metres)
INCLUDES:
1 x 6 Row Oil Cooler
2 x AN6 Push On Hose End
2 x AN6 Hose Finisher
2 x Clamps
2 Metres Nylon Braided Hose
These items are all in stock at our warehouse in Hong Kong and delivery is usually within 3-7 days for most items.
Please PM or contact us if you have any questions regarding these items.
Cheers,
Paul. :bunny:
www.performance-wise.com
www.performance-wise.net
www.yellowjacketscoilpacks.com
https://www.sau.com.au/forums/topic/297874-autobahn88-shop-oil-cooling/
  • 1 month later...
is the thread pitch on the sensor thread 1/8 PT or 1/8 NPT? and does the sandwich plates use the RB oil filters?
Thread pitch is 1/8NPT. You dont use the RB oil filters but you use the RYCO Z160 filter or equivilent. :banana:
  • 6 months later...
in the 15 row oil cooler and filter relocation, It looks like it can run both oil temp, and pressure. Just want to make sure though
Thats correct. There is 2 ports for either oil temp or oil pressure gauges.
:D
So will my normal RB oil filters fit the relocation, or do I have to buy universal ones?
The normal RB oil filter wont fit but the RYCO Z160 filter or equivalent will fit perfectly and wont hinder at all.
:D
  • 6 months later...
ALL PRICES ON OIL COOLER KITS DROPPED!!!
NEW ADDITION...............
FEATURES:
INCLUDES:
2 x Clamps
