Hi all,
Recently dropped an RB25 in my R32 & since first start has never run right.
Is overfueling a stupid amount on idle, (7ms injector pulse width) to the point where it cant be driven due to the amount of smoke & hunting issues (due to mixture I believe...) Thanks to this has been off road for months!
Runs best (but still not perfect) when cold-started but as soon as throttle is touched, even slightly & released, starts pouring smoke & idling like a POS!
Unsure of AFM signal voltage when cold & running half decent but I know after throttle has been touched & its started really putting the fuel in that the AFM signal voltage is around 2v+ on idle!
Car runs good in limp mode with AFM unplugged.
Basically just want ideas of what could cause voltage to be so high?
This is obviously telling ECU more air is entering the engine than what actually is & is causing my problem...
Things I have tried so far include:
*Swapping AFM
*Swapping ECU
*Checking AFM wires for short-circuit
*Measuring resistance of AFM wires back to ECU plug (& ECCS relay)
*Checking battery output voltage
*Checking all earths (battery, body, engine, ECU, etc)
Probably some stuff that Ive missed but will add later...
In the meantime if anyone has anything to add please help me out!
Am even willing to pay for correct information...
Yes, if you solve my problem I will send you money!
https://www.sau.com.au/forums/topic/297893-causes-for-high-afm-signal-voltage/
What is the voltage @ the outlet of the AFM (start of the wiring) vs what the ECU is seeing @ the harness?
Is the 2V @ BOTH ends?? (doesnt sound like you've checked the wirings directly out of the AFM).
If so, then do you know 110% that the other AFM you tried was decent/correct model because it sounds like it's not if the above is 2V @ both ends, it can only be the AFM.
Also, have you tried putting you AFM into another car?
R31 Nismoid: Will double-check but 99% sure voltage is same at AFM & at ECU
Tried another pink-label AFM but had been sitting around for years so unsure of condition, fitted my old RB20 green label AFM (& plug, with a 12v earth)
which I know was working only months ago on my RB20
No, havent tried swapping AFM into another car...
Moodles2: Standard R33 ECU. Have tried 2 other R33 ECUs as well...
Edited by wlspn
Ok check it and let us know - the old AFM from the shed or whatever could well be stuffed too.
I've seen crappy AFM's under and over volt on a few occasions, it is normally undervolting, however i did have one AFM that was always .7V higher for some reason (it was stuffed as well)
Hey mate, just double-checked voltages & they are the same at AFM as at ECU.
Tried mine, another pink label & a green label (with modified wiring to work) & all coming up roughly the same... & as I said I know for sure the green label worked as it was on my RB20 for years & been out for a few months only...
Any other thoughts or ideas?
P.S-On tests I done just then, pink label cold-start voltage was around 1.5v at idle, tapped throttle & jumped to around 2v
Green label (cold-ish) was 1.45v, throttle touched 1.95v
From previous testing if I dont touch throttle at all it creeps up really slowly until its on 2v...
Edited by wlspn
Also thought I should note, just then I checked voltage at ECU, went under bonnet & checked voltage at AFM plug, gave it a small rev at throttle-body & checked voltage again. Could tell as soon as I released throttle that voltage would be up as you can actually hear that the AFM is sucking in more air! Quite a suction noise for idle...
1.3-1.5 is a tad high, but not 'super' high.
It is looking like a TPS issue. If you kick the RPM and it sits higher than it was previous, that would not be AFM, rather the TPS not reading correctly.
1.3-1.5v is the voltage when I first start it & its running sort of OK but still not the best...
Then when you tap throttle, goes to 2v & stays there even after throttle is released.
Also as I mentioned even if throttle is not touched voltage will still slowly creep up until it gets to 2v.
Have tried disconnecting TPS when its running crap, measuring voltages at TPS & ECU + checked resistance of TPS wires back to ECU, etc
If I can get hold of another one I will try it though as I havent actually replaced it at all
  • 1 month later...
are you sure the AFM is the issue here, the AFM will follow the engine
it sounds like the AAC valve is opening and staying open
this would explain why your AFM value increase and then pegs at 2v
whilst the AAC is open, more air comes into the engine
I suppose the only way to check this would be to replace the whole AAC unit with a working item?
Might give that a shot if I can get hold of one... Cleaned it before the engine went in but cant guarantee it hasnt jammed...
upgraded turbo, throttle body and your plenum change has most likely freaked the ecu out a bit much, some cars are fine (at idle and cruise) others just dont wanna play ball, but without seeing it your guess is as good as mine sorry. Duane at hi-torque knows his stuff so im sure he will have it sorted asap.
possible coolant temp sensor if faulty it will send signal to ecu saying engine still cold causing overfueling when warmed up
have seen a couple on other makes of cars that where faulty but not bringing up a fault code.
hard to say withouy a data list on a scanner though.
Edited by MrR33666
Is it idling high? Have you checked the ignition timing, as if it is overly retarded, then the ecu will be trying to raise the idle causing high AFM voltages, though it shouldnt run that rich
No. once it warms up it revs are hunting, very erratic idle... Warmer it gets the worse it is. Once its hot it just wants to stall. Even holding the throttle steady the revs are always changing. Yes, have checked timing, sitting at 20 degrees.
OK, thanks mate, just figure another opinion never hurts. Yes, Duane seems to know his stuff. Hope he will be able to help me out...
No, have checked voltages & resistances as well as replacing with a known working item.
Thanks for all the input though guys. Will be sure to post up what was wrong when I finally find out...
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
