Hi Guys,
Im stripping my car. All work on it was completed by MRC and has had a few hours of use in this configuration.
1. R34 Nur Motor $12000 ONO
This motor was run in for 2000km by Powerplay Imports before I bought it as a long motor. It has done a total of 200km in my car. Have receipt for motor purchase from Powerplay and receipts for work from MRC. It is currently running a gtr sump coverted to rwd with trust trap doors and a metal jacket harmoinc balancer aswell as os giken cam gears but rest of the motor is all nur. I also have the original sump off the motor you can have instead of the rwd one if the motor is going into a gtr. Will come with the r34 cas ($800) as r32/r33 cas dont work with r34 motors. Will also include all intake manifold, fuel rail, butterfly's etc that did not come with the long motor.
2. Garret 3582r .82 $1200 ONO
I have receipts for this turbo from GCG and has been running well in the car for a little over 5000km's. Made 338rwkw on 19psi with full boost by 3500rpm previously and is in great condition. Will come with all water and oil lines to suit high mount rb26.
3. Tial 44mm Wastegate $400 ONO
Was also purchased from GCG (have receipts) and was running for a little over 5000km's.
4. GCG Stainless Manifold $700 ONO
Was also purchased from GCG (have receipts) and was running for a little over 5000km's. Has had slits cut between each of the runners so it doesnt warp.
5. Exedy Hyper Twin Plate $1500 ONO
Includes the lightened flywheel. Clutch has been running for a little over 5000km's and has not slipped once. Very easy clutch to use isnt heavy to push in but does engage firmly.
6. S14a Rear lights and centre garnish $350 ONO
These need no explanation are in good condition.
Only pictures I have right now.
Any questions ask here/pm or on 0403858714.
Thanks,
Brett
Edited by reaper
As can be seen rear lights/garnish are in good condition, all mounts/clips are there. Ignore boot, I sat on it.
Turbo
Any other requests for photo's post here and I'll do the best I can.
  • 1 month later...
    • Ended up spending a WHOLE day yesterday cleaning and rearranging my shed.  Due to the aforementioned disorder, my shed is as cluttered and confused as my brain. Again, because of said disorder,  at any one time there are 5 projects on the go at once and because they're still on the go I don't put everything away so I can "get straight back to it" which rarely happens.. So anyway,  I bought a couple of cheap 2mx2m all steel "pallet racks" to put in my back shed.  The idea is to then take pretty much everything out of the main shed that isn't car related. Most of the garden and building stuff is now booted out to the back shed and onto to the shelves where they belong! There's still more rearranging and reallocating to do and it's still a bit busy in there but it's a massive improvement on how it was previously. I've discovered floor space I forgot I had...  For those that have fully dismantled a car before will understand just how much space it takes up!  Particularly panels, bumpers, engine/trans, etc.  I've got stuff hanging on every available wall to get it up off the floor!  This is not exciting content for a blog but has certainly made the shed feel like a more work ready space now!
    • Updating results from our ATR43SS-1 turbo in T3 .63, OEM bolt dump pattern. Not a big number but pretty sweet for a stock Rb20det. Car's managed to pull 220rwkws at 20psi, perfect boost control internally gated with EBC and excellent mid top end power band as they usually skydive after 5.5K. Usual bolt on supporting mods and inlet plenum and factory location exhaust manifold. Pump 98 fuel was used (Ron 93).
    • Yeah, well, it's not as though anyone is ever going to buy one of those noisy f**kers and put it into a new installation when there are better pumps that are near silent for less money from Ti.
    • I'd suggest having the engine builder listen to it, especially if they assembled it, and minimise how much you run it in the meantime. It may have a serious issue like a big end bearing from the description and I assume the rebuild was not cheap
    • Quite right, typing without checking, it is an 023 which was effectively the replacement for 040 (not that I could find either of them on the Bosch motorsport AU site), and it has a mesh inlet at the bottom of the pump rather than a separate filter
