hello everyone,
i just rebuilded my rb25det and on its first startup there was this loud ticking noise coming from the bottom of the engine, what could it be?
The parts changed on the bottom end are the pistons, main and rod bearings.
First i thought it could be piston slap but doesnt that sound go away when the engine is warming up/ get to normal engine temperature?
We used a stethoscope to listen where the noise could be coming from and it sounds the loudest at the oilpan, could this mean the main bearings arent good?
The noise its making sounds like one of those small air compressors when you're pumping a tire, and when you turn off the engine the last ticking sounds like when you hit the topsite of an empty can/barrel, like tuunk.
The parts used are CP pistons, ACL main and rod bearings and ARP rod bolts.
Could the pistons have been installed wrong?
Apart from that noise the car is idling normaly, its getting good oil pressure, no warning lights when the engine is running.
One more thing about the main bearing, the shop who sold me them sold me main bearings for rb26dett when i asked him if they would fit he said that they are perfectly fine for rb25det and that the only difference is that the rb26dett bearings have 4 extra holes and the one for rb25 has only 1 hole but the measurements are the same.
I would make a vid but i dont want to start the engine again to not risk breaking anything.
Thanks in advance for the help.
(excuse my english, english is not my native language)
https://www.sau.com.au/forums/topic/297912-help-needed-please/
no, i didnt build it. i dont know anything about engines,
only things i know are from this site, thats why i took it to my mechanic. he doesnt seem to recognise the sound either, says it doesnt sound like main bearing.
if theres any more info i need to add let me know, i could make a short vid tomorow if that would help.
i really hope this didnt screw up my crankshaft, dunno where i could get a knew one.
times like this i wish my car was in australia, than i could have taken it to a reputable shop. ;)
  • 1 month later...
Happy new year everyone,
My mechanic figure out what the problem was with the engine. The ARP rod bolts i bought were a bit too long so i bought new ones just incase. Had to re-size the bolts to have enough clearance. He checked if there were any damaged done, didnt see any. The engine seems to be stable and is running fine and i'm in the run-in process at the moment. Hopefuly soon i'll be hitting the 300rwkw mark or around that.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
