Without sounding arrogant, why then does the factory ecu with factory tuning require 2 knock sensors?
Sorry my bad, what i should of said was that it does not visually display knock, like the power fc does.
The standard ECU does though doesn't it?
As far as I know it does. Sydneykid said that knocking on the stock ECU will cause the engine light to flash up, so presumably there are limits to how far it can retard the timing. The PowerFC will flash up the warning light when the knock level gets above 60, which is really useful because this is still below the limit at which you can hear the pinging from the engine.
It's especially useful for poor bastards like me that can't afford the tune yet :D
Hey all,
my car is running a Wolf 3D ecu at the moment and it runs very well. I have only had the car for a week or so but the previous owner has had it in there for a few years now and had it tuned and it is fine now.
BTW, can anyone tell me how to engage the security function on my hand controller as the previous owner is looking for the manual and I don't know how to do it yet
Later
I don't know about all wolf 3ds, but mine cuts fuel and boost above 17psi incase the wastegate etc does'nt do its job or if someone screws around with the bleed valve
This should help
What version Wolf do you have? you can down load the manuals from here
First youll need to know the previous security pin, other than that all u have to do is hold "SET" down when the ignition is off. Holding it down turn the key to ignition and it should prompt you
yeah boost cut, violently cuts the injectors...doesnt feel nice but i guess its better than over boosting 20psi and blowing a rod
I have supplied and fitted many Wolf Plugins inc 9 just before Xmas and love them. Many Wa SAU guys have Wolfs inc WAs toughest GTR ND4SPD using the first GTR plugin, This car drives factory uses less fuel than a standard GTR and has 580rwhp@ only 21psi and a mild tune and GTS tVESPECs GTS makes 411rwhp on a stock motor etc etc. The GTS prototype was fitted by me on an Auto GTS about 2 years ago and it is still going well.Boost cuts can be set at any setting you want and the idle speed control needs to be set up by some one that understand exactly what it dose.
Knock sensors are only in a car to help protect the car from damage.
The damage comes from the fuel not being a high enough octane, in japan they have 99% octane feul as standard, so when jap cars are out here and the fuel is of a much lower standard they require knock sensors to help stop pre and post detonation from happening.
All high end jap cars have this not just skylines, so don't think it's a bad thing or something or anything to do with the computer.
Can anyone confirm that the Plug In Wolf for an RB20 will run low impedence injectors without any dramas' ?
I have a set of GTR injectors all ready to go with resistor pack and an ECU tuned for my turbo and injectors. That said if a Plug-In Wolf will run the injectors without the need to wire up the resistor pack, then i will tempted to bank roll a Wolf ECU.
Looking at the software and brochures it doesnt explicity say the range of injector impedences it can operate.
Can anyone help re the injector impedence question with the plun in Wolf...also you guys using the plug in, what sorts of things are you using the auxillary outputs for?
I'm not sure about that Roy, why dont you give Steve-SST a PM and see if he can help you, he is the man when it comes to Wolf ECU's.:rofl:
As CrazO stated, Steve-SST will be the best person to ask.
As for "auxillary outputs";
1/ One is being used for my shift light. Just using a Jaycar 5" pencil thin neon, which is mounted just below the tacho.
2/ A second output is being used to control the factory boost valve. It is set to 13psi and is very stable.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
