As the title says I have my Bride Zeta III up for sale, I love this seat but I have just ordered a OMP WRC seat to replace this one.
It is very comfy but I wanted higher sides on the base.
This seat is almost 2 yrs old and in perfect condition, the car has only done about 1500 kms since this seat has been fitted.
I will post up pics later tonight but it is new condition no marks at all. It also comes with the Bride super low rails and it is the low max model so it suits the tall bitches also.
Note this seat will not suit people with a larger waist.
The seat is near Newcastle and I am happy to show interested parties.
I am looking for $950.00 for the seat and the rail.
Cheers,
Ryan
Brilliant seat i have the exact same and love it. Tried changing back to standard seat a few times to see if i could part with it but simply cannot drive the 'line without it:) Amazing.. just amazing... and looks great!
Thanks Steven, maybe you should buy the seat for the passenger side and I will sell the rail to Shaun :D
Cheers for the comments.
Then when i pick a heavier set person up they can't get in the car. I've thought about it trust me:P Nothing would be a bigger hint for them to lose weight though ha ha.
By the way for anyone interested i'm 81kg and about a size 34 and fit it with room to lean and pull my phone out comfortably etc.
Good luck!
Free bump... Just wanted to clarify this seat is a Vios III (not Zeta III)... Also Zeta III is not part of the Low Max series and doesn't have the logo "Low Max" on them...
Clearly states on the sticker too!!! ;)
Cheers,
Andy
Thanks Andy, Yep it sure is a Vios III :D
Sorry Shaun no go mate you can buy the rails from Jap land for around $300.00 plus delivery i think???? or you can buy mine and have a spare seat :)
Don't know i never had any dramas with it but i just used the factory seat belt on the street. The Bride rails come with mounts to fit the std buckle to.
The seat might not have to be engineered but maybe the car might have to be re changed to a three seater?
I don't know all the models it will suit but it was for a R33 but going off the sticker on the rail it should fit a lot of nissan models, check the pic above.
still considering my offer?
I have another bloke looking at it locally but i will let you know if i change my mind.
Cheers,
Ryan
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
