  • Replies 196
I do have pics, but I do not know how to attach them into the forum.
It is a grade 4.5/5 Pearl white 260RS with 42k. It has I believe 17" Nisom wheels, but other than that its stock. No final price, but it will be in the $50k- $55k with 12 months rego, new tires.
I will be seeing it at the end of this month and will hopefully have it by the end of Feb. Might even take it to the SAU drags at eastern creek and see if it is the fastest wagon in the world :-)
P.S I cannot seem to get the SAU NSW membership form as the link is broken in Pete's sig. Can someone point me to it, or email it to [email protected]
Thanks
in car  nice
well on the weekend i converted my ca18de silvia to ful "drift" lol spec sr20det
what a mission 35 hours it took
anyone who says the wireing on a ca is the same as a sr is way wrong i can tell you that now
pete
What presure should i be running in my tyres pete?
If i cant borrow a set of ratty rims and tyres from the workshop I take my car to, i'll just have to use the tyres i've got on the car now and buy a new set after.
How much tread do you envisage losing on a drift day? My rear tyres are almost down to their legal limit at the moment, so if I don't replace them before the day I'll definitely be replacing them after!
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
