SAUWA Dyno Day
AutoWorx Wangara
Alistair has recently moved shops, and he and the crew at AutoWorx have invited us for a "Dyno Day" at their new premises!
SAUWA is excited to take up this offer, as it's been a long time since the last dyno day, and we've had alot of new members join since then.
We'd also like to treat this as our final catchup for 2009, so we hope as many people as possible come down to socialise aswell.
Event: ........... "Dyno Day"
Where: .......... AutoWorx, 30 Automotive Drv, Wangara, Western Australia, 6065
When: ............ December 13th. 10:30am - 4pm
Cost: ..............Non SAUWA members $50. SAUWA Members $40 (Membership card must be shown )
Dyno Used: AWD Dyno Dynamics Roller Dyno (in ground)
Classes: ......... Highest HP - RB20
....................... Highest HP - RB25
....................... Highest - RB26 and bigger
....................... Highest HP - Naturally Aspirated (Non-turbo any capacity)
....................... Highest HP Outright
Each category will have a trophy provided by SAUWA!!
Each car will get 3 runs, with a printout of AFR's and Boost available :)
SAUWA will also provide snacks and drinks available at $2 per hotdog and $1 per drink.
There are limited places available so prebook and prepay to me as soon as possible to avoid missing out. Anyone who has booked/paid and does not attend will not get a refund.
Please make sure your car is properly prepared (Fuel, oil, water etc). In regards to low cars, as the dyno is built into the ground there should be no issues with getting on to the dyno.
Please be sure to respect "AutoWorx's" rules! They're providing us a great facility, so make sure you respect it.
We'd like to make this a big event seeing as it's the last for the year, so if you know other people or clubs that might be interested (doesn't have to be Skyline)then please feel free to invite them. If you would like to know anything further please just post it up and ill see if I or someone else can get the answer.
Cheers
Paul
SAUWA President
Bank Details:
Acct Name: Mr Paul R Cornes
BSB: 06 6163
Acct No.: 1000 6120
Please include your "SAU username" and the word "Dyno" in the description
PLACES BOOKED:
1. Esemte - Galant VR4 (Paid)
2. Ten Four - BMW 540i (Paid)
3. Sshonky - S15 (Paid)
4. Sshonky - Stagea (Paid)
5. Hanaldo - R34 GT (Paid)
6. Heller44 - R32 GTS4 (Paid)
7. Pulp - V35 (Paid)
8. gersfan - R33 GTR (Paid)
9. Pal - R33 GTS-t (Paid)
10. Renagade88 - R32 GTS-t (Paid)
11. Hank Scorpio - R34 GTT (Paid)
12. Ossie21 - R33 GTS-t (Paid)
13. reaper83 - R33 GTS-t
14. Boostboy - R33 GTS-t (Paid)
15. 3BEPKA (Paid)
16. Sidewayssam - R32 GTS-t (Paid)
17. Mr Gazza - 350Z (Paid)
18. Bubba - Stagea (Paid)
19. Bubba's mate Mikey - R32 GTS4 (RB30) (Paid)
20. Skitzyrex (Club Motavate) - GC8 WRX (Paid)
21. Nizmo - 350Z (Paid)
22. Leeee (Club Motavate) - R31 RB20DET (Paid)
23. NA Goodness (Paid)
24. Levi - (Paid)
25. StormTrooper (Paid)
https://www.sau.com.au/forums/topic/297948-sauwa-dyno-day-autoworx/
  • Replies 224
Very keen !! I am more interested in how the AFR's are going than the power output.
Would an S15 be welcome too?
With the Stagea being auto ( blerk ) do they just stick it in tiptronic mode and do it that way?
Once I hear back from the Finance Department I will book in for sure
Ok can you book 2 cars in under my username please?
how do I deposit the cash?
1 X Stagea
1 X S15 - if thats ok .. otherwise if its skylines/stageas only then we can leave the s15 out.
Also is it 1st come 1st on the dyno ? Just reason being I need to be out of there by 12 at the latest. ( family commitments )
I really want to get the 2 cars on but also really need to make this lunch ( its the family xmas catchup ) can someone let me know please?
I got $$ waiting to go
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
