SAUWA Dyno Day
AutoWorx Wangara
Alistair has recently moved shops, and he and the crew at AutoWorx have invited us for a "Dyno Day" at their new premises!
SAUWA is excited to take up this offer, as it's been a long time since the last dyno day, and we've had alot of new members join since then.
We'd also like to treat this as our final catchup for 2009, so we hope as many people as possible come down to socialise aswell.
Event: ........... "Dyno Day"
Where: .......... AutoWorx, 30 Automotive Drv, Wangara, Western Australia, 6065
When: ............ December 13th. 10:30am - 4pm
Cost: ..............Non SAUWA members $50. SAUWA Members $40 (Membership card must be shown )
Dyno Used: AWD Dyno Dynamics Roller Dyno (in ground)
Classes: ......... Highest HP - RB20
....................... Highest HP - RB25
....................... Highest - RB26 and bigger
....................... Highest HP - Naturally Aspirated (Non-turbo any capacity)
....................... Highest HP Outright
Each category will have a trophy provided by SAUWA!!
Each car will get 3 runs, with a printout of AFR's and Boost available :)
SAUWA will also provide snacks and drinks available at $2 per hotdog and $1 per drink.
There are limited places available so prebook and prepay to me as soon as possible to avoid missing out. Anyone who has booked/paid and does not attend will not get a refund.
Please make sure your car is properly prepared (Fuel, oil, water etc). In regards to low cars, as the dyno is built into the ground there should be no issues with getting on to the dyno.
Please be sure to respect "AutoWorx's" rules! They're providing us a great facility, so make sure you respect it.
We'd like to make this a big event seeing as it's the last for the year, so if you know other people or clubs that might be interested (doesn't have to be Skyline)then please feel free to invite them. If you would like to know anything further please just post it up and ill see if I or someone else can get the answer.
Cheers
Paul
SAUWA President
Bank Details:
Acct Name: Mr Paul R Cornes
BSB: 06 6163
Acct No.: 1000 6120
Please include your "SAU username" and the word "Dyno" in the description
PLACES BOOKED:
1. Esemte - Galant VR4 (Paid)
2. Ten Four - BMW 540i (Paid)
3. Sshonky - S15 (Paid)
4. Sshonky - Stagea (Paid)
5. Hanaldo - R34 GT (Paid)
6. Heller44 - R32 GTS4 (Paid)
7. Pulp - V35 (Paid)
8. gersfan - R33 GTR (Paid)
9. Pal - R33 GTS-t (Paid)
10. Renagade88 - R32 GTS-t (Paid)
11. Hank Scorpio - R34 GTT (Paid)
12. Ossie21 - R33 GTS-t (Paid)
13. reaper83 - R33 GTS-t
14. Boostboy - R33 GTS-t (Paid)
15. 3BEPKA (Paid)
16. Sidewayssam - R32 GTS-t (Paid)
17. Mr Gazza - 350Z (Paid)
18. Bubba - Stagea (Paid)
19. Bubba's mate Mikey - R32 GTS4 (RB30) (Paid)
20. Skitzyrex (Club Motavate) - GC8 WRX (Paid)
21. Nizmo - 350Z (Paid)
22. Leeee (Club Motavate) - R31 RB20DET (Paid)
23. NA Goodness (Paid)
24. Levi - (Paid)
25. StormTrooper (Paid)
https://www.sau.com.au/forums/topic/297948-sauwa-dyno-day-autoworx/
  • Replies 224
Very keen !! I am more interested in how the AFR's are going than the power output.
Would an S15 be welcome too?
With the Stagea being auto ( blerk ) do they just stick it in tiptronic mode and do it that way?
Once I hear back from the Finance Department I will book in for sure
Ok can you book 2 cars in under my username please?
how do I deposit the cash?
1 X Stagea
1 X S15 - if thats ok .. otherwise if its skylines/stageas only then we can leave the s15 out.
Also is it 1st come 1st on the dyno ? Just reason being I need to be out of there by 12 at the latest. ( family commitments )
I really want to get the 2 cars on but also really need to make this lunch ( its the family xmas catchup ) can someone let me know please?
I got $$ waiting to go
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
