Hey 9k, any updates with the T618Z's? I'd love to see any results if you have them.
Cheers
Justin
very very nice mate. mine is off getting a rebuild at the moment. running t517'z aswell. justwondering what your best power figure was on wht boost with the 2.6 and t517z's. was it still capable of decent response? ive found mine to be abit sluggish but thats with no cams/headwork and factory bottom end untill i get it back
Not to hijack 9k's thread, but in answer to your question...
I made just shy of 400rwkw with a pair of 10cm T517Z's on a 150k bone stock 26. They wouldn't make any more boost than 24psi... even with the actuators wired shut. That was 5 years ago. The numbers were backed up with 136-138mph mid 10 sec 1/4's. That set up lasted nearly 2 years.
Bolt on's only... even the stock exh manifolds were un-ported.
Serously, keep the re-build simple if your staying with the T517z's. Stock- block, crank, rods- all prepped correctly, good oil pump, clean up the head and a 260deg drop in cams.
GL
Justin
Edited by XRATED
  • 5 months later...
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
