Hey guys selling my smashed Skyline.
S2 1997 Model
5-Speed Manual
100,xxx kms
Everything was in good nick, airbags have gone off.
Items damaged:
Front Bar
Rad Support
Head Lights
Bonnet
FMIC
Radiator
Fan
Fan Shroud
A/C Condensor
P/S Control Arm
Rear Bar
Looking for around $4000 as is.
Taking offers on things such as the motor / gearbox and if those two items have a deposit left then I will strip the car.
Motor still runs and car is able to roll.
Also have a brand new turbo-back JJR exhaust with Catco cat bought the day before:
$899 or near offer
JJR Silicon Intake Hose $100
JJR Silicon Radiator Hose $50
im located in vic but if your willing to send the motor to vic ill pay for the cost and put a deposit straight away
also need a couple of parts stock air box with snorkel charcoal cannister heater core component in the dash just the glove box and clips becuse mines broken driver side window control rear seats all the boot carpet trim how much for all this buddy when u have stripped it i am willing to pay for the post my number is 0403011187 my name is v u can text me instead cause im only new to this and its easier for me cuase i dont have much access to a computer thanks mate i probably need some more things to but ill let you no contact me asap thanks buddy also interetsed in after market parts
Rardi the motor is stock and turbo will be included.
Your best off getting quotes for your own postage as I dont have the time to ship myself but am happy to help pick-up.
2566 is the post code.
S2 1997 Model
5-Speed Manual
100,xxx kms
Items damaged:
Front Bar
Rad Support
Head Lights
Bonnet
FMIC
Radiator
Fan
Fan Shroud
A/C Condensor
P/S Control Arm
Rear Bar
$899 or near offer
hey mate, im interested in the dash surround, gear selector surround and plastic mould under steering wheel. Im in sydney , can pick up from you please sms me on 0406747726. Thanks
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
