Ive got a r32.4 project up for sale, put some offers up..!
its a 93 r32gtst
its got a wide body r32.4 conversion
sikk back lights, custom fiberglassed
Gtr rear seats
Front slotted disks
custom rear parcel shelf
Bee-R kit
Sunroof
need a bit more work on kit. but most is on
it has a standard rb20det auto in it, running, just turbo has been pulled out, i still got standard one
ive got
Rb20det wich came out of a drag car, it has
RB20 Turbo engine,
standard internals,
adjustable cam gears,
550cc injectors,
Walbro Fuel Pump,
Stinger 4 computer,
Top Mount Stainless Turbo Manifold,
T04Z spec turbo, High Flowed
FMIC,
TurboSmart
Wastegate,
screamer pipe
BOV,
DualStage Boost Controller. 14p low boost, 19p high boost, currently
Dyno. 310bhp on 19pounds.
R32 Turbo 5speed gearbox,
CarbonTechnic Ultra Race Clutch, ($900clutch kit - trade price)
Tomei Quickshifter,
Hi-Flow Cat,
Free Flow Exhaust(Nice Note).
time card for 12.4 sec 1/4 mile before clutch was put in
guages,
intercooler,
pod filter,
BKR8E spark plugs
Reconditioned Rb20det.
this waz in a r31 drag car, ive got pics of car at drags.
any questions?
anY offers?
https://www.sau.com.au/forums/topic/298010-r324-widebody-project/
how much u looking for ?
no idea mann, i really dont want to sell it, ive spent so much money on parts and so much time on it, but i need money for new house, giv an offer, and i will think...
ill offer 4k sence there is alot of work to be done and it has a stock engine in it and auto
its got a stock engine atm, but ive got a 310bp enine to go with it.. i want a bit more dan dat, just the car alone cost me a bit over 4g
what would you want for it if i took the car only, you can keep the engine, both if you want, and i dont need the rear seats as i already have some,
so car only, how much do you want ?
you can take the car for 5g without the 300+bhp engine.
how much for the modded engine?
ill give all the parts for the moded engine for 3g, or 3.5g with the actual engine. i have it up on parts forums, chek it out
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
