Hello Australia from Siberia!!!I have a Skyline R33 ECR Type-S, RB25DE, 5 manual. At this moment in Krasnoyarsk temperature is -27C degrees, my Skyline is in very hard situation. Sometimes it falls to -40C, -47C :laugh::P:P . But there is one + , I can drift all over the road :P:D:D .
My friend have a Supra (JZA-80, 2JZ-GE) , our yard, is a GT yard :laugh:
Japan cars are the BEST!!!!
:D:D
In Canada they plug there engines into something to stop them from freezing, do you do the same thing over there? Or do you just defrost it the next day ? :D
Are those temperatures only in winter?
Reminds me of a winter I had in Edmonton Alta. (where yes, they warm the block by plugging it in to the household elec.)
Any salting of the roads there?
Went to St Petersburg in '04; but the visit was arranged for June; not winter!
Terry_GT-R34 - no, here roads are sandind (sand), its dont help too much. LSD is helping in that situation.
some_cs_student - time clock. At extreme cold weather, time clock starting the engine each hour. It works some (15-20 min) time and shutting down automatically. Here 8 month in the year is winter (in Jan and Feb super cold) .
johnd320 - 50 % anti freeze (Castrol) 50 % water. It helps up to -50 cold.
DR JOSH - We dreaming about 15C :D:)
sneakey pete - lets change locations :D:D
P.S. sorry for my English ;)
Edited by hicas
Thanks for the reply.
Another question:- How do you source and locate parts and reliable troubleshooting information? I mean there's no Russian translation of a workshop manual (and English is not your 1st language - not that English translation material is that easy to come by either).
Has the Skylines Australia forum or the "ClubSkyline.RU" site been helpful to you? If so, in what way?
P.S. sorry for my English :D
Your english seems fine to me :)
8 months winter....don't think I could deal with that, but the time clock on the car is an interesting concept, I was wondering how it survived without freezing :)
Hicas
Heres mine in Hokkaido, Japan across the road from you guys. Our winter weather comes from Siberia, not as cold as you but does get down to nearly -25+ !
I forgot to put the car in the garage last xmas eve and woke up with hellish hangover and 2 hrs snow shovelling to dig my car out.
The anti-freeze I use is called booze!! Keeps me warm on the inside while well lubricated to function in the cold!!
My guess is you guys in Russia would get parts direct from Japan seeing there are heaps of people exporting cars to Russia from Japan.
Hicas
Good to see the GTR emblem is still visible :D
Hicas: Your english is fine, actually its very good. Are there any problem arising from the cold climate? Rust?
Terry_GT-R34 - thanks to Japan engineers, Skyline still reliable even after 14 yers exploitation, and milage about 270.000 KM (My Sky is 1995 year production), Iam using this Sky 2.5 years, in that period I only change clutch disc (Koreian, I burn it during drifting :P , it costs 60$) , 2 links (QSTEN STB-109 45$) and fuel pump (Masuma 85$, quality of gasoline in Russia is awful). Its normal. In the same period of using, Russian car would collapsed. Of course http://www.clubskyline.ru/ helping some times. There are many users of Skylines, Silvias, Cefiros and other Nissans, there we sharing experience :P
elrodeo666 - You right. There is a site ( http://injapan.ru/ ) from which, you can order any part you Skyline need.
Some time before, I order there a Cusco turnbuckle (125$)
Btw , how much costs Skylines in Japan? Let it be BCNR-33 1995-96 year, or ECR33 with RB25DE?
Let me show you, my elder brother Skyline ---->
And some flaming
:D
Your English is fine ! Certainly better than a lot of others on here!
I could NOT deal with that weather. I seriously feel like capping myself having to live thru a Perth Winter.
( maybe 2 deg C is the lowest it gets)
How do you work on your car? heated workshops I suppose.
So do I understand this right that your car starts itself every hour and runs for 20 mins then shuts itself down ?
Thats pretty cool ! ( pun intended )
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
