just failed a warrant ...too much movement in this bush...the guy at th testing station called it a tie rod but it just a link to the bush ...my question is what is the bush called so i can find a aftermarket one for it ...its at the back next to the shock connected to the link and the hicas lock bar...will link a picturepost-13324-1259364350_thumb.jpg
https://www.sau.com.au/forums/topic/298067-what-are-these-called/
na the guy is right its a tie rod not a bush
needs to be press fitted to the hub so hub will require removal to replace
looking forward to doing it to doing it to mine soon
from memory nissan only for these and not cheap
I couldnt find any aftermarket alternative
