The stud you would be talking about would be right in the middle at the bottom, just cut the stud down so there is enough thread left just for the nut, I have use these manifolds and they are
not the best, they need a lot of work and then they are ok. they need porting at the head flange a 50mm waste gate pipe and the collector needs a lot of work inside. Also to stop them from cracking
add a support bracket off the dump pipe to the bell housing to stop the manifold flexing.
