I have recently bought a 1997 S2 R33, I believe it is equipped with the A-LSD option(has the slip/a-lsd in the instrument cluster).
Now both wheels appear to lock in a straight line, however it appears it just doesnt like corners. With the slip/a-lsd bulbs in the cluster, they never flash, so I figure either something isn't working or bulbs are dead.
Looking in the boot after having a read(1 ecu for hicas and another for a-lsd) I can only see 1? Also, there are a bunch of cut wires?
Also, where is the actual reservoir for the A-LSD fluid, is it the one in the right rear quarter panel behind the little fold down "hatch"?
Pic of diff
IMG_8376.jpg">
Pic of boot/ecu/wires
IMG_8369.jpg">
IMG_8372.jpg">
Pic of under the a-lsd reservoir???
IMG_8378.jpg">
IMG_8379.jpg">
https://www.sau.com.au/forums/topic/298076-a-lsd-questions/
Wow that sucks. Some one has ripped out all the electrics (very dodgy job by the looks of it). That would be why it aint working. Im asuming when you put your key onto ignition the ALSD light and SLIP light don't light up either?
https://www.sau.com.au/forums/topic/298076-a-lsd-questions/#findComment-4960186
Yeah it's an ALSD, easy way to tell is all the cooling ribs on the diff itself, and then the hydraulic lines running to it.
Yeah there is ment to be two ECU's in the boot, one on top of each other. One of your's is missing and the other ECU is just sitting at the back of the boot there.
There's a lot of wires and shit there, i got a feeling some one had an amplifier or something sitting there and took the ECU out.
Personally if i was in your situation, i would rip all the ALSD shit out, buy a normal GTST diff and put a 1.5 way in there. The ALSD is more drama than it is worth. Plus you'll save a fair bit of weight by doing it aswell. Your call.
https://www.sau.com.au/forums/topic/298076-a-lsd-questions/#findComment-4960218
Yeah having a read and all the alsd hate lol, so what Is different? Between the normal LSD and alsd model just a case of swapping duffs ver or other stuff as well? Then what just pull out all of the alsd system which would be the reservoir and the crap underneath, normal r33 diff would just go straight back in with hicas etc?
https://www.sau.com.au/forums/topic/298076-a-lsd-questions/#findComment-4960234
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
