  • Replies 216
Dudes,
I had a set of these on my old GTSt (now owned by MattyB). They have a 4 or 5 step change from blue to green and a 4 or 5 step brightness control too. They look awesome at night, and there is no reflection off the windscreen as Gus said the 'hood' of the dash covers them... They are not hard to install as they sit over the top of your existing guages.. Only problem is you either have to cut through the EL to get them over the needles or take the needles off which unless you are ultra careful will result in incorrect speed, revs, temp, fuel etc....
Definately worth the money...
Rice is nice sometimes... ha ha ha
*raises hand*
If we're looking at Jan/Feb then I'll be in for $200 for EL Kit also...I've wanted some for AGES!
fane,
We can do ours together, I've done some before!*
*Cannot gaurantee accurate speedo afterwards tho! (it's a bitch!)
$160 thats gotta be a bargain
and ina group buy might even be cheaper.
the ones i was trying to organise are going to be $200+
no chance in hell. so I canned it.
guess its down to autoworx and car quest and the spoiler shop
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
