  • Replies 304
Posted Images
Hey guys count me in!!
I'll do the form and transfer once i get paid again next week.
For the cams licence, whats the best class? last time i had one it was an L2S a few years ago, is that still the go?
Yep, I'd say an L2S is the best option, as an L2NS rules out your chances of doing some track days.
L2S = Speed
L2NS = Non-Speed
Paid and such..
We dont have to print out our oun scruitineering sheets this time??
Also wont have membership card as it says is needed for signon cause I havnt gotten anything since joining just before last texi..
Cant wait!!
Finally I've had approval to run Mel's Skyline,,,now to get it ready.
1/ Stole wheels off Duncan with rubbish semi's fitted
2/ Get off my arse and fit nismo locker diff
3/ Buy a bloody race seat cheap
4/ Make bracket for firey thingy.
Neil.
Ok, just gotta recheck engagement party times for the day before. Assuming no hassles with the ex, I wanna be there. So it's 45 for the day, how much is the cams license etc? Just checking how much I'll need all up, plus gotta get an extinguisher sigh.
CAMS L2S licence costs around $100 and last 12 months and is valid at most tracks/events as far as I know. You CAN get a L2NS for around $50, but then you are limited to drifting and events like Texi :ninja:
Fire extinguisher you can get from Autobarn or similar for around $30 - $40.
looks like ill be religated to helping out. Pm me SteveO and let me know what i can do, i dont mind marshalling or cooking...whatever.
Good man, get that clutch in.
Meet at mine on the day, we'll drive up together
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
