  • Replies 304
Posted Images
looks like ill be religated to helping out. Pm me SteveO and let me know what i can do, i dont mind marshalling or cooking...whatever.
Legend!
Marshalling would be VERY much appreciated :D
Clutch is going in the 5th Jan, which will give me time to run it in.
No probs in coming past to go together.
Cool ill go give greg some sh!t and get him to come along. Make sure when you're there you give him shit about oil pumps, he'll know what you mean
if i drop the exhaust after the mufflers under the car is it still classified as sidepipes...
love to have a steer but not sure im allowed. im helping out with marshalling, but might bring her up and see if i can have a run or 3.
Come on Stuart,,,make some adjustments to your exhaust and get out there with us and have a gut load of fun.
Neil.
stu the problem is total noise, no the side pipes per se. can you bolt up a normal, properly muffled system of some sort?
I think you might find it useful in a few places not just here. And there are some things to make sure you do like a 45 or 90o turn at the exit to point the sound downwards that make a big difference in legality. I'm sure Neil has some tips he always struggled with noise from the crapri.
Thanks everyone for the entries - still plenty of spots available though!
i have 2 mufflers now, which is one more than most of you blokes. maybe if i do the seel wool trick. or maybe fit some mufflers that muffle.
are there going to be any power outlets close by to charge my laptop for a bit of data logging? im still trying to work out some issues with the tune.
Not really, unfortunately...
Got a lighter socket in your car still, Joe? There are plenty of transformer/power packs for laptops that just plug straight in.
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
