Texi, Skids On Sunday, Jan 31st 2010
N1GTR
 Share
  • Replies 304
Posted Images
Hey Steveo, My Skyline may be sold by texi, so I may be there in a different car, or my flatmate might take my spot if thats allowed
Yep no probs. Just let me know
Was having a look at pics from previous texi's, and noticed that alot of ppl had the blue battery triangle's on.. Is this a requirment for the day, and is it needed on the roads.. i have been told two different things by two different cops...
Could anyone give me a bit more of an idea on what this is? Do we have timed runs around a short course? Is the skid pan wet (I've never been on one but seen a few that are) and will a set of tyres usually survive the day? It sounds pretty good so far though.
I found this on youtube and if thats it i'm paying asap:
Don't know how well i'll do but my xr6t can make some smoke :thumbsup:
If its raining does it still go ahead or get rescheduled?
Timed yes (but just for fun), Skid pan is dry (unless it rains, like last time), set of tyres will easily last the day - its not a burnout comp. Rain just makes it more fun!
Tyres should most defo make the day, and a few more after it, unless you're one for holding brake +throttle together for extended periods of time...
And that video is from the last Texikhana day the SAU ran.
So yes, exactly that stuff.
bit of a n00b question!
can you apply for your AASA licence on the day just like you can with your cams licence?
i did lastime, check with Duncan I guess, but i'm pretty sure they just fill in the form and accept your money and send it off and give you a slip saying its been paid or something like that...
faxed and paid.
Also with the AASA license i've got one i got from wakefield park that says Club Comp license and it expires in July. That's enough isnt it?
Edited by gregor
Yes, but i STRONGLY advise against it. It takes up an officials time during signon and their time is precious so maybe do it this week ?
any chance of an update of the entrants? Just want to see my faxed form came through ok from dodgy fax at work..... cheers!
About to do that
faxed and paid.
Yes thats fine, bring that with you
Instead of AASA would it be better to get the L2S license? And if so, how do I go about that before the day? Just don't wanna waste time, and have to leave home even earlier =/
gah, have to wait till i get home. mac can't open ashx =/
EDIT:: hurr safari
so it looks like when i send it off i'll just have to keep proof or something... don't wanna have the day come and not have the l2s license and go, well, shit.
 Share
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on.
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
